Introduction: Water Heater Maintenance
Very few people know that in order to keep your water heater running properly and efficiently very simple maintenace procedures need to be performed. (These come with the instructions and are often overlooked.)
As water is pumped into your water heater tank dirt, sediment and various minerals settle on the bottom. Depending on your water quality these extra "ingredients" can add up rather quickly robbing your water heater's efficiency and costing you in the long run. If left unchecked they can not only make your water heater work harder but also allow your tank to rust and slowly be eaten away until you need to replace the entire unit which is very costly yet easily preventable. And cheap to prevent! You just need a hose, bucket (optional) and gloves (optional too, but safer with.)
This Instructable will show you how to perform a simple yearly draining of your water heater to keep it running smoothly.
Step 1: Locate Water Heater
First off, you need to know where your water heater is. This should be very simple. It should be located in your garage.
Be careful! You are going to be dealing with gas/electricity and very hot water and steam.
Step 2: Determine If It's Gas or Electric
This should be simple enough. Look around the tank itself and read any warnings and labels. If you can't determine one sure fire indication is if there is a pilot light odds are it's gas. Mine is gas operated.
Note: Read the instruction on the tank for turning off the gas and or electricity. Don't just do it unless you know what you are doing.
Step 3: Locate Water Shut Off Valve, Pressure Release Valve, & Water Drain
The water shut off valve is located on the top of the water heater. It typically looks like the circular water valves used for front and back yards.
The pressure release valve is located on the top as well. It should have labeling near it. There is piping that leads out of the water heater and into the wall. On the other side of the wall should the the continuation of this piping. It is typically in the front yard or entry way. Make sure it is not obstructed. This is very important.
The water drain is located on the bottom. It is usually a simple spout that has threads so that a hose can be attached. (These threads will be needed for later.)
Step 4: Turn Off Heating Source and Gather Supplies
Now that you know where your water heater is and what it operates with (gas or electric) you are ready to perform it's yearly maintenance. Be sure to turn off the gas to the water heater (if gas) or shut off the circuit breaker if electric. (Again, read instructions carefully.) I did this the night before. This saves the energy it takes to warm the water that you will soon be draining. No need to heat water you won't be using.
Get a hose.
Get a bucket.
Get some gloves to protect you from possible hot steam and or water.
Get a hose.
Get a bucket.
Step 5: Turn Off Water & Attach Hose
Like the title says, turn off the water to the water heater and attach the hose to the water drain.
Step 6: Turn on Water Drain & Then Open Pressure Release Valve
Next you will want to turn on the water drain to release the water from the water heater tank.
The water will drain from the hose and then slowly stop. This is because the pressure release valve needs to be opened to allow air into the tank. A vacuum has been formed and no additional water will be drained from the tank until the vacuum is opened up and removed.
Don't worry if the water is a little dirty as first. That is from all the dirt and sediment that has built up. This is the reason why you are draining it. Get all that stuff out!
Wait 10 - 30 minutes to allow all the water to drain.
Step 7: Turn on the Water to Flush the Rest of the Sediment Out.
Turn off the water drain and remove the hose.
Take the bucket and place below the water drain.
With pressure valve still open turn on the water to the water tank and then turn on the water drain to allow the rest of the sediment to be flushed out. Allow a few gallons worth of water to drain. Be sure to check the water draining out and make sure it is clear. If it is then you are set to refill the tank.
Step 8: Refilling the Tank
Make sure the water drain at the base of the tank is turned off.
Close the pressure release valve.
Turn on the water to allow the tank to be filled.
Once the tank is full you can turn the gas or circuit breaker back on. Caution: Do not turn the heating unit on until the tank is full. If the tank is not full it can cause heating damage to the unit.
Sit back, relax, and enjoy your nice hot water that will be flowing and heating you more efficiently. You got a full year to wait and perform this maintenance again.
Note 1: If you want you can drain a few gallons a month from your tank especially if you live an an area with a lot of sediment in your water. You don't need the hose. Just use the bucket for this month to month maintenace.
Note 2: If you experience any leaks in the water valves or pressure valves be sure that they are tightened correctly. There is a packing nut just below the knob that can be tightened if needed. If the leaking persists then there is a good chance they haven't been used enough and need to be replaced. So be sure to perform this routine maintenace to keep the valve working properly as well!
![Stay Warm Contest](/assets/img/pixel.png)
Stay Warm Contest
