Introduction: Water Level Alarm Using Transistor!!!
Water Level Indicator:
The Water Level Indicator employs a simple mechanism to detect and indicate the water level in an overhead tank or any other water container. The sensing is done by using a set of nine probes which are placed at nine different levels on the tank walls (with probe9 to probe1 placed in increasing order of height, common probe (i.e. a supply carrying probe) is placed at the base of the tank). The level 9 represents the “tank full” condition while level 1 represents the “tank empty” condition.
When the water-level is below the minimum detectable level (MDL), the seven segment displays is arranged to show the digit 1, indicating that the tank is empty, When the water reaches level1 (but is below level2) the connection between the probes gets completed (through the conducting medium – water) and the base voltage of transistor increases. This causes the base-emitter junction of transistor to get forward biased, this switches transistor from cut-off to conduction mode thus PIN (B0) of microcontroller is pulled to ground hence, the corresponding digit displayed by the seven segment display is 2. The similar mechanism applies to the detection of all the other levels. When the tank is full, all inputs to microcontroller become low and all its outputs go high. This causes the display shows a 9 also in this case a buzzer sound is given, thereby indicating a “tank full” condition.
Most water level indicators are equipped to indicate and detect only a single level. The Water Level Indicator implemented here can indicate up to nine such levels and the microcontroller displays the level number on a seven segment display. So, not only is the circuit capable of cautioning a person that the water tank has been filled up to a certain level, it also indicates that the water level has fallen below the minimum detectable level. This circuit is important in appliances such as the water cooler where there is a danger of motor-burnout when there is no water in the radiator used up also it can be used in fuel level indication.
In this project we show the water level indicator using eight transistors which conducts as level rises, a buzzer is also added which will automatically start as the water level becomes full, auto buzzer start with the help of microcontroller. With the help of this project we not only show the level of water with the help of seven segment display but also a buzzer.
Step 1: MATERIALS REQUIRED::---
1.One D882 Transistor
2. Two 100 ohm resistance
3. A bright led (or buzzer if you have)
4. 9 Volt battery with connector
5. Connecting wires
6.Beaker(any container to filled with water)
Step 2: Connect Emmiter to Ground
Step 3: Connect Base to Led With Resistance
Step 4: Add Another Resistance to Collector.
Step 5: Circuit Diagram
here is the circuit diagram procced as it shows...
Step 6: Here`s the Testing...
tip: watch video by decreasing plaback speed for best experience..
