Introduction: Water Marble Nail Art
In this instructable, I'll be showing you how to do this amazing nail art. It looks really tricky, but it's simple once you know how to do it! Marble nail art doesn't take much: all you need is nail polish and water to do it. Keep reading and I'll show you how.
Step 1: Equipment
For this nail art, you'll need:
A container filled with water (preferably bottled water)
Nail polish remover
Tissues
Sticky tape
Nail polishes of your choice
Base coat
Top coat
Tooth picks
Cotton swabs
Scissors
An old towel
**OPTIONAL** - fast-drying nail spray
Step 2:
Paint your nails with a clear base coat. Spray with fast-drying spray if you want.
Step 3:
Paint your nails with the white nail varnish. I recommend 2 coats.
Step 4:
Put sticky tape around your skin and cuticles. Be sure that the tape dosent touch the nail. If the tape is covering the nail, it will ruin the effect, because some parts will be white .
Step 5:
Add the nail varnish to the cup. Put some nail varnish on the brush. Hold it 1 cm above the centre of the waters edge.
Gently tap the handle of the brush until the varnish drips into the water. Add a second colour in the same way into true middle of fat colour. Carry on the pattern in this way.
Step 6:
Using a tooth pick, stir the clear water surrounding the circle of nail varnish. Thus will make the nail varnish ring expand. Make sure the toothpick DOES NOT TOUCH the nail varnish itself, only the clear water.
Step 7:
Place the toothpick on the water, from about the 3rd ring out. Drag the toothpick inwards, towards the centre of the nail varnish. Continue in this way in order to make a flower pattern.
Step 8:
Dip your finger on the water (where the nail varnish pattern is) at a 45 degree angle.
Step 9:
Keep your finger in the water, and use a clean toothpick to roll around the un-used nail varnish to pick it up. Then, take your finger out of the water. Be sure not to smudge the design whilst doing this.
Step 10:
Spray the nail with some quick-dry spray, or leave to dry. Carefully peel off the tape from your finger. Start with the piece that you put down last.
Step 11:
Dip a cotton bus in nail polish remover. Wipe u around your skin to remove any spilt nail varnish. Be carefull around the cuticle, so you don't take off any bail varnish from the actuall nail.
Step 12:
When the nail is dry, paint over it with a
clear top coat. Repeat on all other nails.
Step 13:
And you're done! Hope you found this instructable usefull!
Comment if you have any questions.
3 People Made This Project!
- DrJudyDee made it!
- alannahold made it!
- JenniferG117 made it!
72 Comments
Question 11 months ago
which water u use in the bowl is this some kinda special water or regular pure filter water
Answer 9 months ago
Use boil water
5 years ago
Which works better? Thick or thin nail polish.
Reply 2 years ago
Thin polish. If it is too thick it won't spread.
Reply 5 years ago
thick I think
Reply 5 years ago
thick I think
7 years ago
Mine didn't turn out that great
Reply 2 years ago
I think it turned out great
Reply 5 years ago
Oh come ON!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! urs look wayyyyyy better then mine
Reply 5 years ago
i think they look just fine! :^)
Reply 6 years ago
I did mine this morning and they came out great!!!
Reply 5 years ago
BEAUTIFUL! did you use China Glaze brand, or is that bottle just for the picture?
Reply 7 years ago
I had lots of little water bubbles on my nails when I was done
Question 4 years ago on Step 1
Does the water have to be a certain temperature?
Answer 2 years ago
Room temp is best so that your polish doesn't dry too fast to work with.
Question 3 years ago on Introduction
I tried this today and when I drop my polish in water it just fell to bottom? Does the water half to be warm.. And when I did get my 3 rings I tried to design with tooth pick and the whole thing came on to the pick
Answer 2 years ago
The water should be room temperature. Water that is too cold or too warm will cause the polish to dry too fast. But in your case the water temp isn't the problem. The polish sinks to the bottom when you drop it from to high. Drop it from right above the water. You can even touch the drop while still on the brush to the top of the water and it will come off and spread.
5 years ago
Does anyone know if this works with Zoya brand nail polish?
Reply 5 years ago
it dosnt work with that but with sinful colors it works really well
Reply 4 years ago
Thats great! Because I have Sinful Colors and I looove the colors!
