Introduction: Neopixel Water Mood Lamp
a few days ago I was thinking about the lamp and I suddenly realized that water makes the light spread.
so I decided to make a lamp with water.
this project is very simple and easy to make.
Arduino nano
candy can
tube-shaped bottle
Neopixel
Step 1: Circuit
you have to connect pin6 to Neopixel IN and 5V to VCC and GND to GND.
Step 2: Body
fill the water into the bottle and sill with hot glue and thin plastic
and insert it into the can cab.
Step 3: Electronics
glue the arduino nano and stick the Nropixel to the bottom of the main lamp.
Step 4: Assembling
Assemble are the things you made.
Step 5: Coding
you have to install the Adafruit Neopixel Library in the library manager
and you can find many example codes on the internet.
I used this code
#include <Adafruit_NeoPixel.h>
#define LED_COUNT 6
#define LED_PIN 1
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
void setup() {
strip.begin();
strip.show();
strip.setBrightness(50);
void loop() {
rainbow(10);
void rainbow(int wait) {
for(long firstPixelHue = 0; firstPixelHue < 5*65536; firstPixelHue += 256) {
for(int i=0; i<strip.numPixels(); i++) {
int pixelHue = firstPixelHue + (i * 65536L / strip.numPixels());
strip.setPixelColor(i, strip.gamma32(strip.ColorHSV(pixelHue)));
strip.show();
delay(wait);
Step 6: Testing
test the lamp and you can change the code to change the color .
