Introduction: Water Piano Made Using Glass Jar
This is an amazing and
easy project for everyone. I did not use a microcontroller or an IC. This water piano uses small jars.
This is really a basic project.
To make this project, follow the instructable.
REQUIRMENTS
- jars of any size, atleast 4 to max. 8(use as small as possible).
-5v-12v battery
-a buzzer or(bc547 transistor, small coiled inductor, piezo)
-some wires
-breadboard
-bc548 transistor
Step 1: Circuits
The figure 1 shows the circuit for the piezo speaker, I found a buzzer with same circuit.
The figure 2 shows the circuit for the current coming in keys of piano and going out to the buzzer. The circuled resistor represents the water keys.
The figure 3 represents the water keys for the piano.
Step 2: Making the Circuits
For figure 1, the red wire represents the +ve in and white wire represents the
-ve in. For figure 2, the +ve out is for +ve in and the -ve out is for -ve in, the yellow and grey wires are made for the keys.
For figure 3, put water in jars and make a series connection for all. And put the yellow wire in water and connect the grey wire to your finger tip.
Step 3: Testing the Water Piano Made Using Glass Jar
Now test the piano. I connected a L.E.D. in parallel with buzzer to show you all that the project works.
GOOD BYE FOR NOW! See you in next instructables.
Do not forget to vote me!
Thank you!
