Introduction: Water Spraying Flower Prank
Hi, my name is William and I love designing on Tinkercad and other Websites. When I saw this challenge I thought it would be cool to make the Water Spraying Flower Joke. Using Tinkercad I designed the Flower then I used LEGO Pieces to make the Tube, I then used a small Plastic Bottle for the Sprayer.
- 1 3D Printed Flower(File Below)
- 1 LEGO Tube Connector
- 1 Small Plastic Bottle
- 2 LEGO Tubes
I am aware that some of you that might want to build this and dont have LEGO Tubes or other small Tubes, so here’s the link for the Official LEGO Website and where you can buy individual Tubes and Connectors, LEGO Website Link: https://www.lego.com/en-us/pick-and-build/pick-a-brick.
Step 1: Print the Flower
In this step we will be Printing the most important part, the Flower. Attached below is the Flower File, use this file to Upload the Flower to your Slicing Program, I use FlashForge. I recommend printing the Flower with Supports, Raft, High Quality and 100% Infill. The last two can be changed depending on how strong or light weight you want it to be. Printing should take around 8 hours using the Setting I recommend above. After Print use a Sharp Knife or Tool to carefully remove the Raft and Supports, Be careful not to break the flower pedals they are the most fragile part, but should still be very strong.
Step 2: Connect the Tubes
In Step 2 we will be connecting the LEGO Tubes. First get your LEGO Tubes and your LEGO Tube Connector, then put one of the LEGO Tubes into one end of the Connector, then attach the other Tube to the other end of the Connector. Now you have one long Tube.
Step 3: Putting It All Together
Now that you have all the Parts we have to put them together. First get the 3D Printed Flower from Step 1 and the LEGO Hose from Step 2. Put the Hose into the bottom of the Flower it should be able to be pushed in until it’s firmly in place. Then get the Plastic Bottle and attach that to the other end of the Hose. It should be able to fit into the Hose. That is how you put together my Water Spraying Flower Prank.
Thank You and Hope you Enjoy!!!
