Introduction: Water Timer(idea)
Math Project: Codename Showerhead
Average time spent in shower (BBC): 8 minutes (16.4 gallons per minute)
Average Gallons per minute (BBC): 2.05 Gallons per minute
With the Shower Timer, which shuts off water after 5 minutes plus time needed for hot water to come up, you can save 6.15 gallons! 16.4-10.25
Average Dollars per Gallon: $0.01143
Money saved per shower: $0.072 per shower
What:
Shower Timer that Shuts off water after 5 minutes plus time needed for hot water
Digital
Made of Plastic with electronics inside
Can choose heat with a knob
Beeps every 1 minute and counts down in last ten seconds
Who:
Average family can buy $25
Must have plumber install due to have to be attached to pipes
How:
Shuts off water after 5 minutes no override
Can be turned off earlier but not later
Where:
In shower
Why:
To save water and money
Measurements: Base-4 inches, Width-3 inches, Height-3 inches, Surface Area-66 inches squared, Volume- 36 inches cubed
Step 1: Materials
â¢Tape measure
â¢Circuit board
â¢Wires
â¢1 tube
â¢tin foil
â¢knife
â¢Wood
â¢Timer
⢠Top to oil holder
Step 2: Measurements for Structure
Measure and trace your wood so you have 2 traced out 3x3 pieces of wood for the side, and then trace again for 4 pieces of 4x3 pieces of wood. Then when you got your pieces cut them out.
Step 3: Construction 1
When you have cut out all of our pieces, attach the circuit board to 1 4x3 piece of wood and then attach all of your pieces together. To make a rectangular prism. Put in your timer and wires and make sure that all are hooked up together properly. Make sure that there are no holes or gaps.
Step 4: Construction 2
Now cut a hole in the 4x3 piece of wood so the timer piece of the handle can be shown and used easily, and also to prevent water from leaking in after attaching metal top. Then, make 2 holes on the side with the 2 3x3 pieces of wood. This is so you can attach it with your shower instead of using the normal handles. Then eventually you have a shower timer.
