Water Vortex Mini Fountain
Intro: Water Vortex Mini Fountain
"You can never step in the same water twice, my friend. Like flowing water, life is perpetual movement. There is nothing fixed.” -- Bruce lee
In this intructable I will share my how I made this mini water vortex fountain. Almost, all the materials used in this project are recycled...
I made this project with my son and he enjoys playing with water and experiment with things and observe how it affected the fountain, like putting a marble inside the vortex, adding a pipe or more water.. I hope you get to spend more time with your family and friends by building one..
STEP 1: What Do We Need ?
Material
- Long Glass jar ( Olive jar )
- Plastic Food container with lid (reusing one from last nights food takeout)
- Plastic straw
- DC water pump
- PVC tubes
- Glass marbles
- AC to DC, 9V Adapter ( from old device )
- Wires
Tools
- Drill
- Bottle cutter jig
- Soldering Iron
- Hot Glue gun
STEP 2: The Jar Cap
- It is difficult to drill holes on a glass, so I will use the metal jar cap
- Drill two holes, one at the center and other near the edge
- Make sure there is enough space for a plastic pipe and that the glass jar can still be closed
- Fix the jar cap on the plastic lid of the food container using hot glue gun\
- The middle hole will be used to create a vortex or whirlpool, while the second hole will be use to pump water into the jar at an angle
STEP 3: Bottle Jar
- Cut the bottom of the glass jar using a glass bottle cutter
- Sand the edges smooth
- We will place the glass jar inverted on the plastic lid
STEP 4: The Pump
- The water needs to be pumps inside the jar at an angle, so that the water moves in circular motion
- To make a "L" shaped bend pipe by heating the pipe under a flame and then bending it
- Or cut two pieces of the pipe and attach them at 90 degree by hot glue or melting them together
- The water pump is attached to a plastic pipe using a soft pvc tube, as shown
STEP 5: Finishing
- Drill few extra holes on the food container lid for excess water
- The motor wire can come out at the lid
- Cover the lid with stones or glass marble
- Fill the plastic container with water
Optional :
- Add few lights
- Add blue color or glitter in the water
- Decorate the base jar
Thanks, please share your comments
Penolopy Bulnick 4 years ago
