Introduction: Water Bottle "Magic" Trick
A great "magic" trick to show small kids or a fun way to kill time. Make steam come out of a water bottle without heating it. A simple pressure experiment that is very entertaining.
Step 1: Safety Warnings
1) Make sure you have safety glasses
2) Have a parent/guardian present
3) Do it in an open space
4) Point the bottle away from your body and your face
Step 2: Bottle Preperation
1) Get a softer water bottle. ( poland spring, or nestle pure life)
2) Keep about an inch or two of water in the bottle
Step 3: Twist
Twist the bottle at the center so no water can leak through to the top. There should be a good amount of pressure in both sections of the bottle. You should twist the bottle at least 720 degrees.
Step 4: Spin the Cap a Little
Point the cap of the bottle away from you and quickly release the cover. If you twist the cap too slow then the steam will not rise from the bottle. You need all the pressure to be released at once, not over time. When you twist off the cap correctly, it will shoot out. This is why you point it away from you and others. This is also a good reason to wear glasses. The best way to twist the cap off quickly enough is to hold the bottle itself with you left hand, then with your right hand, hold the top of the bottle. Use your thumb to apply pressure to the start of where the cap can twist. When you use enough force the cap will pop off.
Step 5: Watch the Steam
After the cap pops off, hold the bottle upright and slowly squeeze the top section. This should start to make the steam slowly pour out.
