Introduction: Waterproof GPS Plotter
Openplotter is a fantastic GPS plotter software for the raspberry pi. Its a raspian OS including a SignalK server, an open source day to handle NMEA 0183 and NMEA 2000 communication onboard.
In this instructable I will show how I build my plotter in singel box, waterproof style.
You will need:
- Raspberry Pi 4
-GPS. First I worked with this: http://www.cqrobot.wiki/index.php/Raspberry_Pi_GP...
Its OK, but it needs an external antenna
But the L86 GPS-chip is much better. Now I run the montessiere HAT: https://shop.sailoog.com/openplotter/4-moitessier... This one also supports AIS!
- 12V to 5V converter: https://www.ebay.com/itm/DC-DC-Car-Charger-Conver...
- Arduino pro micro, important: you need the ATMega32U4 chip! This is for the keyboard/mouse control.
Buttons: you need waterproof buttons, I like these: https://www.ebay.com/itm/16mm-Anti-Vandal-Momenta...
Then you need a good box. I went with this one: https://www.ebay.com/itm/Waterproof-Electronic-Pr...
With this box you can squeeze in a 9" display. If you want a 10" (nice) you need to find another box.
Screen: You want a high quality screen with 1000nits so that it works outside in the sun. after lots of searching I got this one: https://www.alibaba.com/product-detail/Outdoor-lc...
Link goes to the 10", you can mail them and order other sizes.
You need a controlled board for the monitor. This one uses 12V in and HDMI in. connects with 50 pin TTL to the monitor: https://www.ebay.com/itm/LCD-TTL-LVDS-Controller-Board-HDMI-VGA-2AV-50PIN-for-VS-TY2662-V1-Driver-Board/264705464702?_trksid=p2485497.m4902.l9144
Also you will need glue and cables, wiring for the buttons.
For the Arduino you need an prototyp PCB, resistors and screw terminals.
I use self adhesive hook and loop fastener for all in-box-fixation.
Step 1: Build the Keyboard
The 32U4 chip can act as a usb keyboard or mouse. solder it on the pcb. connect the buttons as the sketch shows. the buttons are NO, normaly open, if open D-pin goes low. When closed, d-pin goes high.
code for Arduino you find here: https://github.com/ola667/plotter
D2 = Right arrow
D3 = Left arrow
D4= down
D5 = up
D6= zoom out
D7 =zoom in
D8 = follow
D9 = select keyboard or mouse
D2-D8 goes to buttons, D9 - this one goes to a switch
Note: my raspberry is set to Swedish keyboard. haven't tried US, maybe you need to change some ASCCI codes
Look at the "keyboard.write" in the code.
plug the keyboard to a computer and try out the keys.
Then plug it to the raspberry with a usb cable. should be acknowledged as a keyboard
Step 2: Work the Box
Make a hole for the screen. draw a square the same size as the glas of the screen. Drill a hole just inside each side of the square and use a jigsaw to saw it out.
Drill holes for the buttons. Intall the buttons. don't forget the gasket on the inside. you can lay som silicone from the outside for extra waterproofing.
install the screen with hook and loop. This makes it possible to re-fit the screen. it is hard to get it correct at first try.
When the display sits correct, waterproof it with butyl rubber tape from the outside. this is a magic compund, you can buy it from your local car glass workshop.
on the back of the screen I put the screen controller card and the arduino.
Step 3: Cabels
12V power throw a standard cable tunnel
GPS antenna through a cable feeder from the boat store. this one you don't need to remove the contact from the cable.
Step 4:
The raspberry is mounted on 5 mm distances on a 3 mm acryl-plate. hooka and loop between acryl.plate and box. this givs better cooling.
Here I also draw a cable for the AIS and a extra USB to a waterproof usb contact.
