Introduction: Waterproof Speakers That Float - "It Floats, It Totes and It Rocks the Notes!"
This waterproof speaker project was inspired by many trips to the Gila River in Arizona ( and SNL's "I'm on a Boat!" ). We will float down the river, or attach lines to the shore so that our floats stay right by our camp site. Everyone has their own flavor of mp3 player nowadays, loaded with all their faves. I wanted to be able to easily switch between players, yet protect them and the speakers from the elements. This, like many of my projects, has a small budget. Therefore, I try to recycle or re-engineer most, if not all of the parts needed. BTW this is my first instructable so be kind.
*** As always be sure to use proper safety equipment such as eye protection and gloves ***
*** While having tunes on the river is a lifesaver this is in no way a flotation or life saving device ***
Step 1: Collect Tools and Materials
*** Tools ***
1 - Glue gun & glue sticks
2 - Tin snips or sturdy scissors
3 - Screw Driver
4 - Scratch Awl
5 - Hacksaw ( I didn't end up using this, but you may depending on composition of container )
*** Materials ***
1 - Set of small speakers ( I had several old sets and selected based on size)
2 - Large container ( I used bulk size Heinz Ketchup container )
3 - Strap material
4 - 2 wood screws
5 - padding for inside bottom of container
6 - desiccant packs ( recycled from various things that had been shipped to me )
7 - zip tie and self adhering tie mount
8 - small amp ( I recycled mine from free branded SWAG given away at some conference )
9 - ribbed cable protector
10 - small piece of Velcro ( both hook and latch )
11 - small rubber feet (optional)
Step 2: Measure and Cut Container
Begin by measuring and marking where you will be placing the speaker grill. I did this by making a template out of paper so that it would be easier to trace the outline of the speaker grill and mark where the hole will be cut and the screw holes to be punched in with scratch awl. I also wanted to make the actual hole for the speaker as small as possible, while still allowing for the sound to resonate inside the container (also be sure to allow enough room to pass speakers through hole from inside). I have noticed that low end sounds are much better when the container is sealed. After marking both sides, it's time to begin cutting the holes and punching screw holes to secure the grill.
Step 3: Waterproof the Speakers
I wanted to find the best solution for waterproofing the speakers that I had selected, or at least make them water resistant. But, i also wanted to maintain sound quality. The solution that I devised was to glue gun the speaker into the grill with a thin layer of plastic between the paper cone and the grill. I used thin, yet strong plastic from a clear trash bag (black would work just fine). The important part is to stretch the plastic taunt as the glue is cooling, so that it will still transmit sound clearly - much like a tympanic membrane. After the glue cooled, I trimmed away any excess plastic to prevent any buzzing or rattling. It is also important to thread the speakers through holes from inside before sealing it, as the hole is too small for the whole grill assembly to fit through. With this particular speaker grill design, I also decided to use some of the surplus plastic (trimmed from the container) to seal the two sound ports on each grill.
Step 4: Mount and Seal Speaker Grills
Mount the speakers using the holes punched out earlier, and secure them with the screws from the original speaker set. Once the screws are in place, it's time to warm up the glue gun and seal the outer edge of the grill. I also considered using silicone, but since I already had the glue gun out I decided to stick with that. While I had the glue gun hot, I also went ahead and adhered the rubber feet to the bottom of the container (nice for when you are around the pool and when the unit is sitting on a table).
Step 5: Secure Wiring and Install Cord Protector
To be sure the wiring is secure and won't allow tension on the solder points from where I replaced the wiring to the speakers, I used the trusty glue gun to hold in place. I also used Velcro to secure the pad I trimmed to fit the bottom of the container (old foam mouse pad). I felt that i it would be good to have a bilge-like area for water to collect in without compromising the electronics package - for just in case if any water were to condense on the inside. I also used zip tie and tie mount to secure right above the pad.
Step 6: Amp
While the speaker will work well with out amplification, I felt it would make more sense (the white noise from running water will often "drown" out the music) to provide some boost. There are many solutions to this challange (see the many instructables on the topic), but mine was driven by cost and a few other criteria which will come to "Light" later. I chose the re-engineer an amp from some SWAG (stuff we all get)I I picked up along the way. One nice feature this design has is the 6v in port which actually runs of USB voltage. It also runs off four AAA rechargeable batteries that can be charged via the external 6v in or in Arizona the Sun.
Step 7: Final Assembly and Field Testing
Soon to come solar panel that fits in the lid to charge battery pack ($4 sidewalk light from wally world).
"It floats, it totes and it rocks the notes!"
Bench Test
Pool Test
Monsoon Test
Art of Sound Contest
49 Comments
9 years ago on Introduction
Any suggestions on where to find a cheap amp? Or what other items I may be able to pull one out of?
Reply 7 years ago
There are many tutorial about how to make an amplifier,you can search from YouTube or Instructable =) Usually I'll use the same way as Ascars(go search Bluetooth speaker v2.0 and u will see how he make his own loud(seriously,that was really loud) amplifier from scratch ^^
9 years ago on Step 7
i dont get how the speakers can just be exposed to water?
11 years ago on Step 4
i have the same speakers there playin rit now lol. they are loud for there size
12 years ago on Introduction
OMFG! Im a Boy SCOut, and we do crap like canoeing all the time, and we did like last week and I was on here looking for this exact project but i guess you hadnt come up with it! But man this is so sweet, I have to make this for my next venture
Reply 11 years ago on Introduction
I'm very happy that you are excited about DIY projects and are involved in scouting. I am one of many Eagle Scouts in my family and I learned countless things while I was actively involved in BSA, many of which helped to shape the person that I am today.
I encourage you to choose carefully the kind of language you use even in text-ese. Please try to remember to set the right example each day as there are so few who lead by example in our time. Others are counting on you to do so.
Reply 12 years ago on Introduction
Thanks!
so cool
I like this little thing. I am more into turning coolers into radios. This would be good when I can't take my cooler with me .The forums at www.motorboatyourself.com have a lot of good ideas too. How long does this play before you have to recharge it?
11 years ago on Step 6
What kind of amp is it ... Company???
The company I am not sure about but they are everywhere now with various company logo's printed on them. Mine was Verizon swag (stuff we all get) and was free! Here is link to same type though ( http://www.alibaba.com/product-gs/359135963/Folded_Mini_USB_Speaker.html ) if you can't find someone handing them out for free.
13 years ago on Step 7
Needs external volume control... I'm going to make this as soon as I finish my giant container of french vanilla powdered coffee. I wonder if I can make the volume control touch? Also, I was thinking shrink wrap for the covering of the speakers... it can be thin though, but will stretch nicely I think. All in all, I love the idea. Must drink more powdered coffee....
The reason you shouldn’t use touch controls is because the water will affect it.
Reply 12 years ago on Step 7
well if you can take the pot (potentiometer aka the volume nob) and isolate it / mount it outside of the container surround it in hot glue or w/e u want to use and make sure the nob will fit over it and it should be fine
If you could add a solar pannel on the lid to charge your mp3 player then you got your self a million dollar product there!
This makes a great pool toy, I've been looking for a way to waterproof a set of speakers next to the hottub, i've been working on a set of fiberglass enclosures and this really helps solve a problem, Thanks!
Thanks! I use mine at the pool, river, ocean or even on the back deck if it is raining.
I googled waterproofing speakers. and this is what it came up with. My application is for a motorcycle sound system. because in oregon it is illegal to have headphones in while riding or driving. I have all the stuff i need but couldnt figure out how to waterproof the speakers rather than paying $250 bucks for a set. Granted im only useing part of your ideal but the whole thing is great probably make one later. thanks
Awesome, glad this helps!
Cool Idea man. I just did basically the same thing but I used much more/larger speakers out of an old stereo and just stuck it all in an igloo cooler. The sound is slightly muffled through the cooler but it's still a whole lot louder with considerably more bass than smaller speakers (similar to the size you used) that I tried to waterproof like you did. Keep an eye out for my instructable on the cooler radio
