Introduction: Waterproof Fire Starters
There are many ways to make fire starters that can help you make fire when the circumstances are not ideal, for example high humidity, wet branches etc.. They can burn for even 10-15 min depending on their size, which is more than enough to make a fire.
Step 1: The First Way
For the first type of fire starters you will need a candle, or a piece of wax and some sawdust. Cut the candle, put it in a can and place it on fire to melt the wax. When the wax is melted add sawdust. Put as much as possible sawdust to be able to make pieces as in the first photo. Use The wick of a candle to lit the fire starter easily. "Bake" the thing you made around the wick and you are ready to use your fire starter.
Step 2: The Second Way
You need a candle, matches, a napkin or a piece of paper or textile and a piece of thread. Wrap a napkin around a match, or around several of them, and tide it with the thread. Dip it in the melted wax, take it out, let it harden, and there you have it.
