Introduction: WaveForms™ Analog Discovery™ on Zybo
This instructable provides instructions how to setup WaveForms-3 application on Zybo using Xillinux.
The WaveForms application is the interface for the instrumentation products: Analog Discovery and Electronics Explorer. These incorporate oscilloscope, logic analyzer, arbitrary waveform and digital generators, power supplies.
Needed hardware:
- Digilent products:
- Zybo (Xilinx ZYNQ) with micro SD card
- Analog Discovery or Electronics Explorer
- Powered USB hub
- Mouse and Keyboard
- HDMI or VGA monitor
Step 1: Setup Linux
Please refer to the licensing terms of Xillybus Xillinux and Xilinx Vivado.
Linux image
Download xillinux-1.3.img.gz
Extract and copy this image to SD card.
On Windows the Win32 Disk Imager application can be use for writing to the card.
This image, now the SD card, has two partitions. The second partition contains the Linux. The first, boot partition is FAT. From Windows only this partition is visible. We will have to copy tree more files to this.
Boot files
Download: xillinux-eval-zybo-1.3b.zip
Copy the boot.bin and devicetree.dtb form ZIP file bootfiles directory to the root of first partition of the SD card.
Zynq hardware
Download the prebuilt xillydemo.bit or generate it as described in the following manual: xillybus_getting_started_zynq.pdf
Copy the bit file to the first partition of the card.
Step 2: Start Linux
Eject the SD card from your computer and plug it in Zybo.
Make sure the JP5 is set to SD boot.
Connect:
- Power from USB or WALL 5V
- Ethernet cable with internet access
- Powered USB hub
- Mouse & Keyboard
- Flip the power switch to ON position
Start the graphical interface on your Zybo by entering into the shell
$ startx
Step 3: Install Software
Download and install the following packages:
In case you have any question please visit the Digilent Forum.
