Introduction: Waving Wood Flag
In this tutorial I’ll show you how I made my “Waves for Days” flag out of 2x4’s
8- 8’ 2x4’s
Rit Dye blue and red
Polyurethane
Star Stencil
Bandsaw or jigsaw
Rotary Tool
Mitre Saw
Angle grinder
Brad Nailer
2” Brad nails
Polyurethane
Star Stencil
Bandsaw or jigsaw
Rotary Tool
Mitre Saw
Angle grinder
Brad Nailer
2” Brad nails
Step 1: Making the Template
To make the template for the waving effect I cut out a 2x4 13” longer than I wanted my stripes to be. My flag was 36” so I cut this piece at 49” Then I drew on a wave pattern that I thought looked ok and cut it out on a bandsaw. I then marked lines 1” a part all the way to 13”.
Step 2: Making the Stripes
I cut out each stripe to length on the mitre saw. Then I took my stripe template and traced the wave pattern on to it. Then for all the consecutive stripes i moved the template 1” down and traced the pattern for each of the 13 stripes, and labeling each stripe as i finished.
Step 3: The Grind
Next I cut out each stripes wave on the bandsaw. Once you finish, line all the stripes up in order and you should have a cool wave effect. Then the fun part begins. I clamped each stripe together and used an angle grinder with a shaping wheel to grind down all the offset pieces so it all looks nice and smooth. Then i used my palm sander and sanded through 600 grit to finish.
Step 4: Burn and Stain
After the sanding is finished, burn each stripe just enough to bring the grain of the wood out. Once burned, i lighted sanded it again and wiped it all down before the stain. I used Rit Dye for the stain and stained each stripe individually before i glued it together. This saved a TON of time taping. Once stained i used a high gloss polyurethane on all the stripes individually as well. The stain will bleed so i didn’t want to risk any of the color blending together.
Step 5: Glue Up
Once the poly dried I glued and nailed each stripe together one at a time. Be careful not to use too much glue. You don’t want any to sleep out on the poly. Once everything was dry I traced on the stars with a stencil and cut each one out individually. Hope you enjoyed this tutorial!
