Wearable LED Matrix Face Mask
Intro: Wearable LED Matrix Face Mask
Basically just a 12 x 16 pixel LED matrix made into a wearable mask. A high impact polystyrene plastic base plate with 142 pixels of WS2812B 60 LEDs per meter strip attached. Each pixel is independently controllable from a single tiny Pixel Controller Ion. The controller allows customized patterns and color sequences to be created on a computer using the software, NLED Aurora Control, then uploaded/saved to the controller for it to run independently. The color sequence creation software NLED Aurora Control is used to design the color patterns, it features several ways to create a visual representation of the project which makes it quite easy to create the custom color sequences most projects require.
Added 10/30/2018: Developing an LED project guide for all things LEDs and pixels. https://www.nledshop.com/projectguide/
STEP 1: Parts and Supplies
Additional information on parts selection can be found on the NLED Project Guide. https://www.nledshop.com/projectguide/
Parts:
- Pixel Controller - Recommend: Pixel Controller Electron(more memory) or Pixel Controller Ion
- WS2812B LED Strip, 60 LEDs Per Meter, used 142 pixels worth
- Momentary Push Button, PCB Mount - Included with Pixel Controller Ion
- 18650 Lithium Battery
- 18650 Battery Holder - Digikey: BK-18650-PC2 - Or make one.
- 2.1mm x 5.5mm panel mount barrel jack
- Wire with 2.1mm x 5.5mm barrel plug - scavenged from wall-wart PSU
- Aluminum Tape
- High Impact Polystyrene sheet or Acrylic - 8.5" x 11" piece used for this project
- 50 Mil HDPE plastic sheet, or other type of plastic for diffusing
- Sheet of White Packing Foam - The flat kind used for wrapping things
- Paintball mask strap - scavenged
- Scrap medium density foam blocks
Tools:
- Solder Iron
- Electronics Tools - Pliers, strippers, electrical tape, etc
- Pop Rivet Gun
- Pop Rivets - used 1/16" white ones
STEP 2: The Face Plate
The main structure of the mask is a 1/8" high impact polystyrene plate bent to form around a face. The easiest way to make a LED matrix is to use a flat surface. Ideally the mask would have a lot more to it, but being completely flat makes the LED strip go down easier and lay flatter. A mask pattern was created through trial and error in Illustrator. And was mocked up in cardboard to get the right shape and eye hole spacing. Missed some pictures in the early stages.
Cut Out The Plastic Plate:
- The cut pattern was printed onto paper and taped it to a the piece of HIPS, about 8.5" x 11"
- Cut out the pattern using a band saw.
- Drilled a pilot hole and used a jigsaw to cut out the eye holes.
- Sanded the edges and eye holes til it was symmetrical and smooth.
Bending:
- Tried to place it in a solder reflow oven(since that was the most convenient and had precise temperature control) at about 120F, and brought the temperature up slow. It quickly went from soft but not yet moldable, to nearly completely melted real quick. Let it cool for a sec and then was able to reshape it and mold it.
- A heat gun was used to reheat areas to make them playable to be able to shape it. A small plaster bucket happened to be the right size and did just the trick to form the plastic plate into the approx shape required.
- The shape of the mask tapers, wider at the top, narrower at the bottom, with the ends bent in. Repeatedly tried it on and made adjustments til it fit correct.
STEP 3: LED Placement and Wiring
LED Strip Placement:
- Cleaned the face plate off thoroughly with rubbing alcohol to get any dirt or oil off.
- Used the pattern to mark the rows on the face plate using a pencil.
- Plan what row/pixel will be #1 and start from there.
- Applied the LED strip in straight lines and straight columns. Leaving some space on the outer edge to hide any wires.
- Applied all the LED strip, keeping it straight and orderly. The strip is controlled uni-directionaly, so make sure that the ends(In and out sides) are positioned properly.
LED Strip Data Wiring: The theory is to connect all the LED strip rows into one long string. For WS2812B only the DAT pads have to be connected in order. Ground/V- and +5v can be connected anywhere on the strip, it doesn't have to be on the ends.
- The IN for row #1/Pixel #1 had a 3-pin JST-SM connector attached. The wire leads were shortened first.
- Connect DAT out of row #1 to DAT In of row #2 using a piece of stranded wire, trimmed to minimum length
- Continue connecting the DAT out of one row to the DAT in of the next row. Until every row has their DAT(data) pad connected OUT to IN.
LED Strip Power Wiring: Ground/V- and +5v can be connected anywhere on the strip, every row needs a connection to them. Pictures of power wiring were lost. But simple enough.
- Connect every divided section of LED strip to +5v and GND/V-
- Used red wire for +5v and green wire for GND. Should have used white instead of green since it shows through a bit.
- Connected pads mostly in the middle of the strips, snaking from vertically. Left the end of the strips just for DAT connection.
STEP 4: Diffusing, Straps, & Electronics
Some steps did not have pictures taken during assembly.
Diffuser:
- Before starting the diffuser mounting, drill any holes for power and controller connections.
- Placed a sheet of cellular packing foam over the entire mask, over the edges and held temporarily with tape.
- Placed a sheet of 50mil HDPE sheet over that, which also went over the edge.
- Clamped both sheets to the face plate using small clamps.
- Re-positioned both sheets so they fit correctly.
- Marked and drilled 3x evenly spaced 1/16" holes down one side of the mask through the HDPE, cell foam, and face plate.
- Using 1/16" pop rivets, the 3 holes were riveted. Securing all 3 pieces together.
- Removed the clamps and smoothed out the diffusing sheets.
- Repeated on the other side, with 3 more holes and pop rivets.
- Flipped it over, and used a sharp razor blade and the face plate as a guide. Then trimmed the HDPE and cell foam flush to the edges of the face plate.
Straps and Mounting: Seemingly the hardest part was to get it to fit right. A head strap from an old paintball mask was used for holding the mask on and some foam blocks were added for comfort and for positioning. It was found that adding a chunk of foam to the forehead area made it more comfortable, as the strap tension would make the mask pivot off the forehead which kept it from rubbing on the face/chin. Overall its fairly comfortable, all things considered.
Power and Battery: This project utilizes a single 18650 for power without a 5 volt boost. This will work fine for some projects that need to be kept simple. For higher quality results utilize a suitable 5 volt step-up.
- A 2.1mm x 5.5mm barrel jack was connected to the power wires. Note there are 2 runs of power, one from the bottom rows and one from the top. Although they are connected together on the strips, it helps to have multiple 'home runs' of power to provide the required current when its needed. 142 pixels could draw up to 8.52 amps.
- The battery holder shown is made from a piece of thin aluminum square tube, that was formed into a holder for a 18650 using some shapelock plastic and wire.
- A scavenged cord(from a wall wart PSU) with a 2.1mm x 5.5mm barrel plug was added to the battery holder. It mates with the panel mount barrel jack that hangs off the mask. There is no switch the mask is turned on and off by unplugging it for now.
Controller and Wires:
- Use any kind of permanent tape to secure the controller and wires. Aluminum duct tape, gaff tape, or other type.
STEP 5: Control and Software
Controller: The controller chosen for this project was the Pixel Controller Ion. A very small(0.6"x1.25") controller with USB, onboard memory for storage of color sequences, single multi-use button, and compatibility with many pixel chipsets(WS2801, LPD8806, LPD6803, APA102, WS2811, etc with more to be added, request if you want one). It is compatible with NLED Aurora Control for creation of stand-alone color sequences. The controller comes in several different configurations, making it easy to implement with most any project.
NLED Aurora Control - Stand-Alone Color Sequences: Used for the creation and upload of stand-alone color sequences to compatible NLED controllers. Once uploaded the controller can run the color sequences by itself, without a computer connection. Find all the information, downloads, and documentation on The NLED Aurora Control Webpage
Newest version allows a pixel map to be loaded and used to visualize the physical layout of the LED pixels. This makes it very easy to design color sequences for your custom project. The software NLED Matrix Patcher is a free, open source Processing application, originally for use with NLED Matrix.
NLED Matrix - Live Control with Video and Effects: Is an open-source Java based application used for mixing and controlling video content and to output it to a custom DIY LED Matrix or matrices, which can be of any shape and size. NLED Matrix supports pixel patching, which allows the user to create the order in which the software outputs the data to the LED Pixels. That means any shape of LED matrix, any layout, any color order, with any type of control scheme can be made to work with the software. It allows two feeds of video data, either from a file such as .MOV, from an image, from a external video feed, or from any of the numerous generated content. The mixed video feed can be sent over Serial(USB Adapter, or RS-485 adapter), TCP, or UDP.
The configuration files for this project can be found in the download, or with the new version of NLED Matrix. This project requires special pixel patching, as it is not a standard shape(square or rectangle). The image with the blue dots is the a screen shot of the pixel patch from the patching software, NLED Matrix Patcher(which is also compatible with NLED Aurora Control)
STEP 6: Finished
Thanks for reading, please visit www.NLEDshop.com for Made In The USA LED Controllers and LED Products.
Or find more projects that utilize NLED products on our Instructables Profile or the Projects Page on our website.
Please Contact Us with any questions, comments, or bug reports.
NLED is available for embedded programming, firmware design, hardware design, LED projects, product design, and consultation. Please Contact Us to discuss your project.
Updates and More Info Can Be Found On The Project Webpage: http://www.nledshop.com/projects/ledmatrixmask/
13 Comments
MacS5 5 years ago
NLED-Projects 5 years ago
schwendigo 5 years ago
thanks for the tutorial!
one question - how could ~140 pixels draw over 8A when the pixels use 1.92A/meter (one meter being 60 pixels)? By those calculations, I'm getting a max of 2.5A.
Is it 1.92A.meter per each color?
I'm trying to figure out what AWG to use and also remain safe (it's for my kids), and also I'm using a tiny 3.7->5v step-up board that doubles as a battery chassis.
whopoder 8 years ago
É o que eu sempre pretendi fazer, mas não sabia como :D
COOOOOL!
juggnate 8 years ago
This is exactly what i've been looking for, for the past couple months. Thanks for doing this
Zhisi 8 years ago
How much it costs aproximately?
Tom De prins 8 years ago
Maarkaus 8 years ago
Could mod this to be Rorschach mask. Cool idea.
mkarimi2 8 years ago
Da boss battle 8 years ago
seamster 8 years ago
Nice project! This is really cool. I like the ninja turtle configuration a lot!
