Wearable Neopixel Sparkle
Intro: Wearable Neopixel Sparkle
Who doesn't want a bit of extra sparkle in their everyday life? This simple wearable is easy to make (if you know how to solder) and very comfortable and light. Inspired by the wonderful Adafruit Neopixel Crown, but a bit less labor-intensive, and with a much lower profile.
STEP 1: Gather Materials
For super low-profile wearables like this, you really can't find a better board than the Tiny Lily. I absolutely adore this teeny tiny arduino. The size makes it easy to add to almost any project, the round form factor makes it perfect for wearables, and it's STILL as powerful as the Lilypad Arduino.
3. Neopixels
For this project, I used these Mini PCB Neopixels. But either the Breadboard Friendly or the Flora Smart Neopixels would be a little easier. For this exact project, I'd choose the Breadboard Friendly ones.
4. Wire. I used this ribbon, zippable, 28 AWG, lead-free wire from Digi-Key.
5. Battery
STEP 2: Gather Tools
1. Soldering iron
2. Wire-stripper
3. Hot glue gun
STEP 3: Wire Everything Up
The Neopixels are generally very well-labeled. V+ on the Neopixel connects to V+ from the Tiny Lily. GND connects to Ground. The signal from the Tiny Lily goes to the IN pin of the first Neopixel. The OUT pin from that Neopixel connects to the IN pin of the next Neopixel, and so on. Chain together the Neopixels in the configuration that you'd like to use. I didn't want to have to use any kind of external structure, so I made mine very simple.
The wires hold everything together. Be sure to test the connections as you're going. Once you're satisfied with the soldering, put some hot glue on the solder joints for strain relief.
If you're new to soldering, you can check out Adafruit's Guide to Excellent Soldering.
STEP 4: Upload the Code
I haven't found a better sketch than this one, posted by johncarl81. It was ported from the LolShield for use on Neopixels. The patterns it makes are mesmerizing: both unpredictable and very smooth.
To load this onto your project, you'll need to edit two lines:
https://github.com/johncarl81/neopixelplasma/blob/...
The first parameter of that constructor is the number of LEDs attached, and the second is the pin they're connected to. In the original sketch, there are 40 Neopixels connected to pin #6:
const int NUM_LEDS = 40;
const int LED_PIN = 6;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, LED_PIN, NEO_GRB + NEO_KHZ800);
You'll need to update those numbers to work on your project. For instance, if you have 5 Neopixels connected to pin #1, those lines would look like this:
const int NUM_LEDS = 5;
const int LED_PIN = 1;
For this project, my 3 Neopixels are attached to pin #3, so it looks like this:
const int NUM_LEDS = 3;
const int LED_PIN = 3;
You can also play around with the parameters. For instance, these two lines have an effect on the speed and colors that you'll see:
STEP 5: Connect It All Together, and Wear It!
Note that the TinyLily connects to the Battery Adapter in a non-intuitive way. You need to connect it so that two pins are "in" the adapter, and three pins are out. Apparently there was a small error in the design process.
This little battery is light enough to simply tuck underneath the LEDs. I hold it in place with some bobby pins. It's so light I usually forget it's there.
If you wanted to make this blend in a bit more, you could use wires that are the same colour as your hair. Personally, I enjoy the way the wires look. I wonder how this would look in blonde or gray hair!
6 Comments
DIY Hacks and How Tos 8 years ago
Those look great. This would be the perfect addition for a lot of Halloween Costumes. You should definitely enter this in the Wearble Tech contest.
molecule13 8 years ago
Oh! Wearable Tech contest?! That does sound perfect! Thanks for mentioning it I didn't know it existed :)
That does sound great... do you have any tips for finding these contests? I am having trouble seeing any kind of link to them. Google brought me to the 2014 halloween contest page, and changing the URL didn't help. I can see the Featured Channels at the bottom of this page: Is there a "Featured Contest" somewhere?
https://www.instructables.com/contest/halloween2014costume/
At the top of the page next to the search bar, there is an "Explore" button. This creates a drop down menu where there is a button for "Contests." Or you can just go to this link: https://www.instructables.com/contest
There you will find the list of all the current contests. If you see a contest that fits your project just go to the contest page and click on "Enter." Also when you publish an Instructable, there is an option for entering contests right when you publish the project.
Ooh thanks very much for those step-by-step instructions :) Got it now! Also found the "first-time author" contest which my other Instructable is eligible for.
