Introduction: Wearable Survival Kit (With Tech Additions)
Hello there! Here is an instructable about making a survival kit which can be worn on your wrist! All you are going to need is:
A small plastic box (used here is a TicTac box)
Matchsticks (2)
Part of the ignition strip on the side of the matchbox
BandAid
A Dongle with a working internet connection plan and also with a SD card slot, for using as a flash memory medium
A calculator-watch
Sports Wristband
A thin band (elastic)
A mirror stuck on a piece of cardboard
Step 1: Making the Miniature Essential Survival Kit
Firstly, we will make the miniature essential survival kit which includes all the materials seen in the picture
Step 2: The Fire Essentials
Take two matchsticks and the strip cut from the side of the matchbox
Step 3: BandAid
Take the BandAid, which should preferably be of a well trusted company, for you cant take chances when on survival mode
Step 4: Writing Instrument
Take a thin ball pen refill, and cut it according to the size of the survival kit box
Step 5: Fitting the BandAid
Fold the BandAid according to the size of the kit box
Step 6: Fitting the Matchbox Strip
Fold the strip according to the need of crunching it in the kit
Step 7: Fitting the Matchsticks
Take the two matchsticks and cut them if necessary, but a suggestion is, try not to cut the matchsticks, for the more wood you have, the longer it will burn
Step 8: Fitting the Refill
Take the already cut refill and fit it in the box
Step 9: Fitting Everything
Take the box
Step 10: Fit Everything
Step 11: Making the Ultimate Wearable Survival Kit
Take all the materials shown in the picture
Step 12: Take the Calculator Watch
Make sure each key works
Step 13: The Dongle
Insert the SD card in the dongle and you get both the dongle and the pendrive
Step 14: Pocket Mirror
Step 15: Elastic Band
Step 16: Fixing the Objects
Arrange and fix all the objects as shown
Step 17: Fixing the Objects
Fix everything and dont forget to attach the Survival Kit too
