Wearable Toy Piano
Intro: Wearable Toy Piano
A Toy Piano embedded on a T-shirt. It has 8 keys from Do to Do (1 octave). You can play simple music by wearing the shirt and pushing the fabric button on the shirt. All the components from the toy piano (batteries, speaker, circuit board) are placed on the shirt and connected with poppers. All these hard components are detachable so that you can wash it if you wish.
This particular Instructable is made for the Electronic Textile workshop that will be held in Zurich/Switzerland on Saturday 7th December 2009 as part of the DIY Festival Zurich. If you are interested in this workshop, please contact the festival.
STEP 1: What You Need
What you need:
-Toy piano (batteries included)
-T-shirt
-conductive fabric
-conductive thread
-normal thread
-neoprene (or normal thick fabric)
-fusible interface (iron on)
-3mm foam sheet
-ink jet iron on paper
-poppers
-electronic wire
Tool:
-needle
-scissors
-iron
-hammer
-soldering iron
-ink jet printer
-screw driver
-T-shirt
-conductive fabric
-conductive thread
-normal thread
-3mm foam sheet
-poppers
-electronic wire
Tool:
-needle
-scissors
-iron
-hammer
-soldering iron
-ink jet printer
-screw driver
STEP 2: Open the Toy Piano
Open the Toy piano casing with screw driver.
There are circuit, speaker and batteries inside.
STEP 3: Prepare the Circuit
connect wires to the metal bits of the circuit. there are small metal part above the button (looks like black painted thing). this will be one side of the button (switch). The other side of the black bits is connected all together on the circuit. connect another wire to the metal part of this connection (in the picture, I am calling it as base). Make a loop at the end of each wire and hock it on the metal popper's leg and place it on the base fabric (In this picture, I used white neoprene) It is more stable if you use thick and stiff fabric.
STEP 4: Battery Case
Here I am using neoprene, but you can also use other kinds of stretchy fabric as well. Use fusible to stick the conductive fabric on the tab part of the material (small round shaped part). make sure that the conductive fabric side faces inside so that it touches the battery. place the popper on the flapping side of the tab so you can connect to the T-shirt.
STEP 5: Speaker With Popper Connection
STEP 6: Print the Circuit Pattern Onto the T-shirt
print the circuit pattern onto the T-shirt by using the ink jet iron on paper.
I made a circuit pattern with illustrator and printed on iron on paper.
Then the parts are cut and placed onto the T-shirt and ironed on.
STEP 7: Iron on the Conductive Fabric
for the base side of the button, I have used conductive fabric stripes placed as the pattern using fusible interface.
STEP 8: Make Buttons
cut the 3mm foam to the size of the button, make a hole in the middle and close it with the other side of the button. Do not forget to put the conductive fabric on this side of the button as well. The connection from the button is made with conductive thread. It is stitched to the bottom of the T-shirt
STEP 9: Make All the Circuit Connection
make all the circuit connection following the pattern with conductive stitches and conductive fabric strips using fusible. connect the poppers at the end of the line so that the circuit, batteries and speaker can be connected.
STEP 10: Connect All the Components
Now place all the components with poppers and it is ready to go!
STEP 11: Here Is My Friend Playing Some Strange Tune...
The plan was to place 2 of the button under arms... but it was a bit far inside.. next improvement point... The sound is not very loud, but it makes nice electric guitar like noise.
33 Comments
J-Five 11 years ago
J-Five 11 years ago
And could make some money, if you sold them to people.
porcupinemamma 12 years ago
codongolev 15 years ago
jedi pen-gui-n 15 years ago
maybe_i_dont_care 14 years ago
Miss_LyLa 12 years ago
sonicsizer 12 years ago
lizlock681 13 years ago
I need to find conductive fabric and thread, if you have any leads, please let me know.
Also, I can't open the pattern. My version of Illustrator is older than yours. Can you save it as a pdf and put it on this site or email it to me at lockwooddesign@yahoo.com.
This shirt is just too cool for words. I'm new at doing things like this, but can't wait to give it a go.
I turned a pair of adult sketchers into light up ones tonight using the info from someone on this site. Believe it or not I am a grandmother, but love cool stuff.
And I really don't care much about what others think, well a little, but I have a really neat, awesome pair of sneakers. I'm trying some led projects also.
Again, thanks so much for posting this t-shirt.
madest 15 years ago
thinkdunson 15 years ago
imrobot 15 years ago
Valche 15 years ago
daphnedaf 14 years ago
equiliberator 14 years ago
TechNerd1012 15 years ago
jclaw 15 years ago
