Introduction: Weather Forecasting and Interfacing DHT11 Sensor With Mediatek Linkitone Board
In This Instructable, You Will Be Able To Do weather Forecasting using DHT11 Humidity and Temperature Sensor.
Step 1: Requirements
DHT11 Temperature and Humidity Sensor
Jumper Wires
USB Cable for Board
Jumper Wires
USB Cable for Board
Step 2: Connections
VCC : +3V3 On Board
Out :D4 Digital Pin on Board
GND: Ground on Board
Step 3: Code, Compile and Run
Upload The Code, Import the header file attached above And You Can See The Output On The Serial Monitor Depending Upon The Environment Conditions.
Congratulations!!! You Have successfully Interfaced DHT11 with LinkIt One Board!!
