Introduction: Weather Wall Frame
Ever wonder whats the weather right outside your house?
This DIY Weather Wall Frame gathers data from your backyard and and provides his users subtle indications of the weather outside your apartment/house.
Weather Wall Frame is designed to convey concise information about weather outside the user’s residence. It consists of two modules which work with each other in order to create a glanceable display and convey information about the climate that is specific to his residence.
Step 1: DataGetter
Description:
The DataGetter module is placed just outside the house within the range of an internet WIFI connection to sense data such as humidity, temperature, light intensity, heat index and dew point using sensors. This information is then uploaded into a cloud to be used by the display module.
Components:
DHT22
light sensor
Photon
Jumper Wires
Bread Board
4.7k Ohm Register
10k Ohm register
Circuit:
Refer the image above for circuit board connections.
File:
WeatherDataGetter.ino
Compile and flash the above file using web IDE called https://build.particle.io or flash the WeatherDataGetter.bin on the photon
Step 2: Display
Description:
The Display module is a wall Frame programmed to access the weather data on the cloud and display it on the wall frame. It gives subtle hints about the climate outside so that the user might take necessary precautions while going outdoors.
Components:
LED's (Green-1, Blue-1, RED-1, White-1, Yellow-2)
Servo Motor
Photon
Jumper Wires
Bread Board
Circuit:
File:
WeatherAmbientDisplay.ino
Compile and flash the above file using web IDE called https://build.particle.io or flash the WeatherAmbientDisplay.bin on the photon
Step 3: Files Required
The above INO files contain the codes for the photons which need to be compiled before flashing, whereas the BIN files are the per-compiled and could be directly flashed on the photons.
