Which MICROCONTROLLER for Your ELECTRONIC FASHION?
Intro: Which MICROCONTROLLER for Your ELECTRONIC FASHION?
What Does Fashion Lack? "Microcontrollers" I always answer - and it's TRUE! It makes your garments SO much more interesting, interactive and communicative as soon as you add some INTELLIGENCE to it.
But which ones are on the market?
I started a little research on available on some of the hottest SMALLEST boards at the moment:
If you have any recommendations - please feel free to help me with my challenge of finding the BEST microcontroller boards AROUND!
STEP 1: MY CHOICE: TEENSY 3.1
Why? Because it's SUPER small, reliable, affordable and adorable. The only downside I could discover was the color green. But teensy-creator Paul Stoffenregen recently added a PURPLE one to the repertoire. In collaboration with OSH Park
The tiny board runs a full 32 bit ARM processor which is a similar architecture to what is used in many mobile phones today. It's using an adapted Arduino language called 'Teensieduino' - a software add-on for the Arduino, to run sketches on the Teensy and Teensy++. It is also possible to program this board directly with C or still use the Arduino IDE with just a small patch. Teensy 2.0 runs 5V, teensy 3.0 runs 3.3V and the newly introduced Teensy 3.1 ($19,80) runs both 5V tolerance on digital outputs as still running on 3.3V as well. Today most new chips use 3.3V signals, but many legacy products output 5 volt digital signals this was a little bit switching back and forth between Teensy 2.0 and 3.0 prior.
Also - on the Teensy 3.1 the RAM has quadrupled, from 16K to 64K. While 16K is plenty for nearly all Arduino libraries, 64K allows for more advanced applications. Icons and graphics for color displays and audio effects requiring delays, like reverb and chorus, will become possible on Teensy 3.1. Flash memory has doubled, to 256K, and provides double the memory bandwidth.
A perfect controller for more advanced projects that can make use of the power available on-board.
Teensy website: https://www.pjrc.com/teensy/index.html
Level: MEDIUM
STEP 2: TO KEEP AN EYE ON: INTEL EDISON (released at End of Year)
I am EXCITED for this BADASS board for a longer time because of multiple reasons: the first is that it features integrated Wi-Fi, Bluetooth* LE, memory, and storage which most boards don't have next to being a strong board regarding to processing power and reliability. The SD-card sized Intel® Edison development platform (announced at CES during January 2014) is the first in a series of low-cost, product-ready, general purpose compute platforms that will be released at the end of this year and will support for more than 30 industry-standard I/O interfaces.
But the best of it all: they focus on the fashiontech market; which they don't only see as wearable electronics, but also thinking more ahead and supporting the more experimental (and not yet proven) field of electronic textiles and electronic fashion - a risk not many company's yet take at this moment.
Th description is as followed: "Intel® Atom™ system-on-a-chip (SoC) based on leading-edge 22 nm Silvermont micro architecture including a dual-core CPU" no further specs to be found. We keep an EYE on you, Edison!...
Level: UNKNOWN
STEP 3: A GOOD PLACE TO START WITH: ARDUINO
Arduino has been around for ages: it created it's own little world, community - even speaks it's own language! - a more simplified version of C++ it's an open-source electronics prototyping platform based on flexible, easy-to-use hardware and software. Intend for artists, designers, hobyists and anyone interested in creating interactive objects or environments. The microcontroller on the board is programmed using theArduino programming language (based on Wiring) and the Arduino development environment (based on Processing). Arduino projects can be stand-alone or they can communicate with software running on a computer (e.g. Flash, Processing,MaxMSP). The boards can be built by hand or purchased preassembled; the software can be downloaded for free. The hardware reference designs (CAD files) are available under an open-source license, you are free to adapt them to your needs.
The full Arduino family you can visit here.
Arduino website: http://www.arduino.cc/
STEP 4: WIRELESS Choice - ARDUINO FIO
Fio seems to be the most versatile board design for more complex wearable projects at the moment and has a big interest from the fashiontech community. A big feature is that it comes with an ON-BOARD XBEE compatible slot on the back which makes your project WIRELESS CONTROLLABLE in an instant and lets you connect any device with an XBEE footprint!
The Arduino Fio is a microcontroller board based on the ATmega328P (datasheet) runs at 3.3V and 8 MHz (unfortunately). It's an 3.3 volt board compatible with the very common 3.7 volt LiPo batteries with a charging circuit when the board is plugged in via the USB port. Programming of the FIO is easy since you don't need an FTDI breakout like some of the boards (like Arduino Mini) need.
Ideal for simple wireless XBEE-based projects that don't need that much processing power.
Level: MEDIUM
STEP 5: MENTIONABLE - Smal But Rusty: ARDUINO PRO MINI
A super small and cheap board based on the ATmega168 (datasheet). The downside is that it needs an FTDI breakout in order to program. If you are ok with that - totally fine. But if your system is build into a little casing like mine (and pluggable through the encasing) it's not ideal. And if using LiPo batteries it doesn’t have a built in charging circuit.
Level: MEDIUM
STEP 6: CUTE and ROUND: LILYPAD ARDUINO
The LilyPad Arduino is a microcontroller board designed for wearables and e-textiles it's intend was to be brought to the DIY and sewing-community back in the days and it seems to be sucessfull! I started using Lilypad's next to Arduino back in the days for prototyping and testing, but I decided that I wanted to play with the 'real deal'. Though - Lilypads are cute, especially their round form factor gives leading your wires a very easthetical approach.
The LilyPad Arduino is a microcontroller board designed for wearables and e-textiles. It can be sewn to fabric and similarly mounted power supplies, sensors and actuators with conductive thread. The board is based on theATmega168V (the low-power version of the ATmega168) (datasheet) or the ATmega328V (datasheet). The LilyPadArduino was designed and developed by Leah Buechley and SparkFun Electronics.
Level: EASY
STEP 7: COMPATIBLE PARTS: XADOW (SEEED STUDIO)
The XADOW works with compatible parts! With that they are trying to design a new way of embedding of your system within a flexible surface while you can switch using switchable connectors in between different modules such as Main Board, LED, OLED, barometer, Xadow BLE Slave and more, within a snatch of your finger. Engineering made easy! This is a perfect choice for prototyping in where you don't want to have the burden to solder everything together before a 'proof of concept'.
Level: EASY
STEP 8: CONNECT TO ANDROID: IOIO (pronounced "yo-yo")
The IOIO is a board that provides a host machine the capability of interfacing with external hardware over a variety of commonly used protocols. The original IOIO board has been specifically designed to work with Android devices. The newer IOIO-OTG ("on the go") boards work with both Android devices and PC's (details here). The IOIO board can be connected to its host over USB or Bluetooth, and provides a high-level Java API on the host side for using its I/O functions as if they were an integral part of the client.
Level: can be HARDER
STEP 9: SUPER SMALL PROJECTS - Use a GEMMA!
Gemma is a miniature (size of a quarter!) wearable electronic platform designed by Adafruit and is heavily related to the Flora; the Gemma is great for really small projects that don’t require a whole lot of I/O. Drawback is the lack of a serial port which makes debugging sketches difficult.
Level: SUPER EASY
STEP 10: SEWABLE MODULES - FLORA
Flora is AdaFruit's answer to the Lilypad - though it has a slightly more diverse ecosystem. There are many sewable modules available, from high end GPS antenna to colour light sensors. Though sewing in my circuits still doesn't feel like such a good thing at times - make sure you secure everything very well and don't use that much stretch on your wire.
Level: EASY
STEP 11: STAY TUNED...
As I will keep refreshing this topic!
LOVE and happy creating <3
14 Comments
Pedro_Azevedo 8 years ago
Depending on what you want to do, LightBlue Bean looks quite interesting.
Programmed wirelessly via bluetooth, 3-axis accelerometer, temperature sensor, RGB LED, 6 digital I/O pins, 2 analog pins, ...
And, is small as a bean (a big bean).
http://legacy.punchthrough.com/bean/
The Bean+ is coming:
https://www.kickstarter.com/projects/1966384672/a-bluetooth-arduino-for-the-mobile-age-lightblue-b/description
diy_bloke 8 years ago
Great overview. Just a few remarks: the pro mini now pretty much standard has a 328 rather than a 168.
The Gemma as you say doesnt have a serial port but you overlook that it has a USB port so debugging is a breeze and even easier than with serial as many computers dont even have a serial port anymore.
Dont rule out the attiny85. Though that doesnt come as a ready made board it is very practical for tiny projects
As with sewable boards, I usually use some strong regular thread with a brandname Ironthread (called 'Iron' for its strength, not because it contains iron) and then make the electrical connections with conducting wire.
THE.DOUBLE.SS 9 years ago
hi
did u try to outout audio via Intel Edison kit expansion
ty
regards
Alderin 9 years ago
You are missing the Moteino from http://www.lowpowerlab.com, very small Arduino software compatible board, comes with RFM12/RFM69 wireless communication modules (though available without) and optional SRAM on board. Very low price, very easy to use.
jack1986 9 years ago
Someone did gave their answer, with a cheaper&stronger Arduino-compatible controller:http://www.elecrow.com/blog/elecrows-answer-for-electronic-fashion/
veeguy 9 years ago
These tiny micros are great for wearable fashion, they are able to be almost undetectable in the finished garment. My idea goes in the opposite direction... For workout clothes or exercise gear, take a step back into the 1980's. A Zilog Z-80 development board featured 4K random access memory, 8K Eeprom and a compliment of 8 i/o plus a microsecond resolution timer. it fit into a 4" X 6" package and only consumes 250 mA (milliamps, not micro or nanoamps!) making a lead acid gel cell battery mandatory if you needed a runtime past "several minutes". You program it in Z-80 assembly language, as God intended programming to be conducted in
This micro eliminates the need to use separate weights or carry auxiliary equipment, for your workout, as the minimum unit (micro/battery/doodads) weighs about 4 pounds. The up side to this setup is it allows the use of incandescent lights and klaxons in place of those pesky LED's, EL wire and piezos.
After all, if you wear workout clothes, it *should* be a workout.
-Just my 2 cents worth... (that's 2 pre 1984 COPPER cents Missy)
Kweek 9 years ago
For SHAME!! You have completely excluded http://digistump.com/ !Their new digispark pro is extremely compact and fairly powerful. They have and fairly comprehensive selections of shields, and the prices are fantastic.
XTL 9 years ago
The micropython board has similar capabilities and you can program it in Python - which is much easier IMHO.
Sorry but its also green :)
http://micropython.org/
akonradi 9 years ago
If you're looking for cheap, I suggest the Arduino Pro Mini from Sparkfun. You'd need a separate FTDI cable, but if you're buying in bulk, these might end up being cheaper.
rma3 9 years ago
Hi Anouk!
Loved your show at Makerfaire San Mateo! :D Here is an awesome little board by Tiny Circuits- hope this helps you in your quest for the smallest boards! ^^
http://tiny-circuits.com/products/tinylily/
audreyobscura 9 years ago
Those are awesome.
JanaMarie 9 years ago
Very cool!
ndragovich 9 years ago
andrea biffi 9 years ago
very interesting, thanks!
