Introduction: That's Hot
How to use Arduino and 16x2 LCD display room temperature and set a desired temperature.
*You can switch between Fahrenheit and Celsius.
*You can set up your desired temperature.
*When the temperature higher than desired temperature,
the LED will be lighted.
Step 1: What Do You Need?
Arduino UNO
Breadboard
16x2 LCD
Temperature Sensor
Wires
LED
Potentiometer
Button
Resistors
Step 2: How to Do It?
Example Code :
#include
LiquidCrystal lcd(12, 11, 5, 4, 3, 2); int buttonPin = 9; // pushbutton pin const int temperaturePin = 0; //Temperature sensor pin float voltage, degreesC, degreesF; int displaysetC, displaysetF; //The value used to display the disired temperature float set; //The Value read from potentiometer const int PotentiometerPin = 1; //PotentiometerPin boolean button; //The button pushed or not int buttonState;//Variables to hold the pushbutton states const int led = 13; // LED pin void setup() { // Set up the pushbutton pins to be an input: pinMode(buttonPin, INPUT); // Set up the LED pin to be an output: pinMode(led, OUTPUT); } void loop() { Potentiometer(); Temperature(set); Button(); LCDdisplay();
int Potentiometer() //Read the value from potentiometer and return it.
set = analogRead(PotentiometerPin);
set = set / 32; //Make the value fit Fahrenheit
set = set + 60;
return (set);
float Temperature(float set) {
voltage = analogRead(temperaturePin) * 0.004882814;
degreesC = (voltage - 0.5) * 100.0;
degreesF = degreesC * (9.0 / 5.0) + 32.0;
int barD = (int) set; //Round the value from potentiometer
set = (float) barD;
displaysetC = set - 32; //Make the value into 5-33 to fit Celsius
displaysetC = displaysetC * 9;
displaysetC = displaysetC / 5;
displaysetC = displaysetC - 40;
displaysetC = displaysetC / 2;
displaysetF = set;}
int Button() {
// read the current pushbutton states into a variable
buttonState = digitalRead(buttonPin);
if (buttonState == LOW) { //If the button pressed, switch the state
button = !button;
void LCDdisplay() {
int barF = (int) degreesF; //Round the value before display
degreesF = (float) barF;
int displayF = degreesF;
int barC = (int) degreesC;
degreesC = (float) barC;
int displayC = degreesC;
lcd.begin(16, 2);
if (button == true) { lcd.print(displayF);
lcd.print(" Fahrenheit");
lcd.setCursor(0, 1);
lcd.println(displaysetF);
lcd.println("DesiredTemp");
if (displayF > displaysetF) {
digitalWrite(led, LOW);
else {
digitalWrite(led, HIGH);
if (button == false) {
lcd.print(displayC);
lcd.println(" Celsius");
lcd.println(displaysetC);
lcd.println(" DesiredTemp");
if (displayC > displaysetC) {
else {
}} delay(500); }
Step 3: Important Code
// include the library code:
#include
// initialize the library with the numbers ofthe interface pins
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("hello, world!");
// (note: line 1 is the second row, since counting begins with 0):
