Introduction: What Is a Resistor | Basics
If you have ever built a circuit, then you might have come across this component, this is a resistor. So how does it works let’s find it out!
Step 1: Watch the Video !
I have made video on Youtube which is much easier to understand check it out !
Step 2: Basic Introduction
Resistor is an electrical component that resists rate of flow of current and unit of resistor is Ohms.
it is represented by two symbols show above.
Ohm's law
The current I is equal to the voltage V divided by the resistance R
also represented by V=I*R
Step 3: Resistors in Series and Parallel.
The equivalent resistance of resistors in series is the sum of the resistance values:
Req= R1+ R2+ R3+...
Therefore equivalent resistance increases
Resistors in parallel
The equivalent resistance of resistors in parallel is given by:
(1/Req)=(1/R1)+(1/R2)+(1/R3)+...
Therefore equivalent resistance decreases
Step 4: Voltage Drop
This happens when resistors are connected in series and the drop in the voltage can be calculated using the formula
V1=(R2*V)/(R1+R2)
Step 5: Power Rating of Resistor
There are various types of resistor such as Shunt, Power, Variable etc.
But most importantly Power rating is a crucial factor while designing the circuit or else You can see what can happen in the circuit in this Video.
Step 6: Application
Step 7: Thank You
If you like my work
Feel free to check out my YouTube channel for more awesome stuff: https://www.youtube.com/c/Nematics_lab
You can also follow me on Facebook, Twitter etc for upcoming projects and behind the scenes information
https://www.facebook.com/NematicsLab/
