Introduction: Wheelchair Camera Holder
a camera stand that connects to a wheelchair and allows handicapped people to use a camera without holding it.
Step 1:
download the .stl files and print them.
We used the 3d printer settings below:
PrusaSlicer PETG 0.4mm
nozzle Layer Height: 0.5mm
Line Width: 1.0mm
Wall Thickness: 1mm
Print Speed: 35mm/s
Retraction Speed: 35mm/s
Infill density: 80%
Infill pattern: Grid
Supports: Everywhere
Step 2:
Bend a 22mm diameter tube according to these parameters twice:
Step 3:
Mill a 22mm diameter rod according to these parameters:
Step 4:
Drill holes as described and tap an M5 thread
Step 5:
Assemble the two pipes and the rod together when the bores are at the same point
Step 6:
Insert the plugs into the bottom of the pipes
Step 7:
Insert 3mm rods into the axis of each of the 3D printed pars, then cover them with the tap.
Step 8:
Glue the anti-slip rubber strips to the inside of the connector
Step 9:
Use a welder to heat the 5M nuts and insert them into the dedicated slot.
Step 10:
Insert the velcro strip into the dedicated slot as depicted
Step 11:
Assemble all the parts together, then attach to the wheelchair and start shooting awesome videos :)
