Introduction: Wi-Fi Network As Access Point (AP Mode) on DragonBoard 410c With Debian Operating System
This tutorial shows how to configure a Wireless network as Access Point (AP mode) on DragonBoard 410c with Debian Linux operating system, using Network Manager via command line (CLI) and graphical user interface (GUI). It also presents the necessary steps to configure a wireless connection to start every time as AP mode on Linux.
Step 1: Prerequisites
Step 2: Network Manager - GUI
This section shows you how to configure a wireless connection as AP mode using the user interface (GUI):
Preferences -> Network Connections
Step 1: Select the Plus (+) button;
Step 2: Choose Wi-Fi as Connection Type;
Step 3: Set up the Access Point
- SSID;
- Mode;
- Band;
- Channel;
- Device;
- MTU.
Step 4: Set up the password for the Access Point (e.g. for a WPA2 AP).
Step 3: Network Manager - CLI
Here are steps to configure a wireless connection as AP mode using "nmcli" command:
1) To create a WIFI Access Point, first create the connection:
nmcli con add type wifi ifname wlan0 con-name dragonboard_ap autoconnect yes ssid dragonboard_ap
2) Set up the Wi-Fi as AP mode:
nmcli con modify dragonboard_ap 802-11-wireless.mode ap 802-11-wireless.band bg ipv4.method shared
3) Set up the password for your access point (e.g. for a WPA2 AP):
nmcli con modify dragonboard_ap wifi-sec.key-mgmt wpa-psk nmcli con modify dragonboard_ap wifi-sec.psk "1234567890"
4) Enable the connection:
nmcli con up dragonboard_ap
Step 4: Wi-Fi As AP Mode on Startup
Here are steps to add the wireless connection as AP mode during the Debian startup using systemd:
Step 1: Create the script /sbin/apmode.sh
#!/bin/bash nmcli con add type wifi ifname wlan0 con-name dragonboard_ap autoconnect yes ssid dragonboard_ap nmcli con modify dragonboard_ap 802-11-wireless.mode ap 802-11-wireless.band bg ipv4.method shared nmcli con modify dragonboard_ap wifi-sec.key-mgmt wpa-psk nmcli con modify dragonboard_ap wifi-sec.psk "1234567890" nmcli con up dragonboard_ap
Step 2: Adding execution permissions
chmod +x /sbin/apmode.sh
Step 3: Create the script /etc/systemd/system/apmode.service
[Unit] Description=Job to startup the wireless connection as ap mode Wants=network-online.target After=network-online.target [Service] ExecStart=/bin/bash /sbin/apmode.sh Type=oneshot RemainAfterExit=yes [Install] WantedBy=graphical.target
Step 4: Enable the service
systemctl --user daemon-reload systemctl enable apmode.service
Step 5: Reboot
