Introduction: WiFi Outlet X2 Raspberry Pi
This is ongoing project You can find my other previous projects here
https://www.instructables.com/Wifi-Outlet-X4-Raspberry-Pi/
https://www.instructables.com/WiFi-Outlet-Raspberry-Pi/
https://www.instructables.com/Raspberry-Pi-IoT/
With this project you can control any outlet via internet from anywhere in the world! I have several and use them for security deterrent, my bedroom control laziness from my bed. There is also the ability to upgrade to have multiple sensors! This is my mini version and cheapest. BTW this not NOT AI associated and FASTER THAN!!!! By the time you can say "Hey google" I could have turned it on/off by hand 100 x's! Build yourself a better smart home than Bill Gates!
i love this project it's my favorite one!!!!
*Note for future.
So far currently if you did want sensors you'd have to drill a hole. If I get better luck working with them and finish up the software I'll make another version of this. using a rj-11 connector to I2C.
*History
The original idea started in 2016 with a friend no longer here. As you can see I did it backwards. I started with the full IOT project and worked my way down to now this version the mini. I just haven't went bigger yet. It's been many years I've wanted this to be done. THIS IS TRUELY THE FUTURE IN YOUR HANDS! Come to think about it it might also be Nikola Tesla dream?! If you think about it, the picture of it by itself. If you seen it as his eyes and then popped back in his time. By all definition he would think it's a wireless electricity box. Just something to THINK ABOUT!
Raspberry Zero W (I prefer 1.1 because 2.0 is not needed no difference)
32GB GB micro SD card 100/MBS
U.FL IPX RF SMD female
U.FL /IPX to RP-SMA female antenna wire
SMA female 11cm wifi antenna dual-band (can be upgraded if needed more distance go bigger size)
upgrade heatsink if can
1A USB power adapter wall charger
AC power IEC standard C-14 Inlet connector snap-in
(2) AC outlet NEMA S-15R 3 wire 15A snap-in
(2) General purpose relay DC 5V 20A
(2) NPN transistor 3904
(4) 1K 1/4W ressistor
(2) doide 1N4001
(2) LED red 5mm
Mis wire
hardware
Other- hot glue, liquid tape, solder, UV super glue, super glue
3D parts
Total cost $51.60
Step 1: Raspberry Pi Command Line
Download and burn image to micro sd card
Go through settings and enable Remote GPIO
sudo raspi-config
Personal settings
sudo nano /boot/config.txt
add to bottom
avoid_warnings=1
Save and Exit. Next we change settings at startup
sudo nano /etc/xdg/lxsession/LXDE-pi/autostart
add these lines
@xset s off
@xset s noblank
@xset -dpms
(comment out screensaver with # like # @xscreensaver)
Save and Exit. Next we can set static IP
sudo nano /etc/dhcpcd.conf
Goto Bottom and add
interface wlan0
static ip_address=192.168.2.190/24
static routers=192.168.2.1
static domain_name_servers=192.168.2.1
save and exit. Next Wifi Settings
sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
country=us
network={
ssid=""
psk=""
key_mgmt=WPA-PSK
Save and Exit. Now we'll Reboot for settings to take efect.
sudo reboot
sudo apt-get update
sudo apt-get full-upgrade
sudo apt-get -y dist-upgrade
Now Install Python
sudo apt install python
sudo apt install python3 idle3
To get sensor working.
git clone https://github.com/adafruit/Adafruit_Python_DHT.git
cd Adafruit_Python_DHT
sudo apt-get install build-essential python-dev
sudo python setup.py install
Next we'll do Apache webserver
sudo apt install apache2 -y
Next we need permission for ftp to transfer files
cd /
cd /var/www
sudo chown pi: html
Next we change the port # of the pi
cd html
sudo nano /etc/apache2/ports.conf
change "Listen 80" to Listen 8030 Save and Exit
Now install PhP
sudo apt install php
Set permissions on ppi for browser access
sudo visudo
add the following lines at the bottom
www-data ALL=(ALL)NOPASSWD:ALL
www-data ALL=/sbin/reboot
www-data ALL=NOPASSWD:/sbin/reboot
www-data ALL=/sbin/shutdown
www-data ALL=NOPASSWD:/sbin/shutdown
www-data ALL=/sbin/sysctl
www-data ALL=NOPASSWD:/sbinsysctl
Save and Exit.
cd ..
In the "www" folder run command
sudo chwon -R www-data:www-data /var/www
Next WE NEED Wiring Pi ABSOLUTE MUST!
cd ~
In "home/pi" folder
sudo git clone https://github.com/WiringPi/WiringPi
cd WiringPi
sudo ./build
Now you can read GPIO pins
gpio readall
Now you should be all setup that you can put the ip address and port that we had assigned in your web browser in view what we have!. Currently there should be some sort of basic index.html page there. Finally here is the link you NEED to download and unzip to replace in the "html" folder. I used filezilla to ftp to the pi and transfer the files. [/var/www/html/] If doesn't work change file permissions. There are many ways you can do this but I just do this in FTP and do all the files in folder to 777. Click link for code package
https://github.com/ScottieD369/Raspberry-Pi-IoT/raw/main/Pi%20Server%202%20Mini.zip
I can say there is a "hidden feature" in IE browser! via pc. Then you can use any browser on ANY device to view! These lovely buttons love to change color! Just like anything else if you want to access this outside your network port forward on router! Yes tested and WORKS! ***PLEASE NOTE***(Your IP and port may differ? Just change in the files.)
http://IPADDRESS:PORT/index.html
Then if you have port forward that port the IP becomes the IP of your location NOT the pi!!!
Step 2: 3D Printing
Step 3: Soldering
It's best to setup the micro SD card before doing ANYTHING That was when your done it's ready for TESTING!
Now first step and MUST be first is air solder the U.FL connector (EXTREAMLY HARD!!!)
If you need help or idea I found this on youtube
https://www.youtube.com/watch?v=Y648CjIiEv8
Now as you can see I popped in the outlets.
It's nice to pre-solder everything
I use a cut-off wheel to remove power supply from USB
You can plug up the power cable to soldering the Inlet to make sure the pins are aligned! For just in case purpose. Soldering to them pins can get HOT and cause the plastic to slightly melt and cause misalignment.
Relay 1 = GPIO 5
Relay 2 = GPIO 6
Sensors are optional
Step 4: Glue Mounts
Use plain super glue for mounts
Now you can also UV super glue the outlets IF you like? I prefer extra safety
I show picture of removal of washer so you a NICE fit on antenna! It is slightly short.
Step 5: Troubleshooting
Give yourself plenty of wire length for troubleshooting and or replaceing
Step 6: Mounting
place screws in place to measure distance. and determine how far.
Next pilot hole and screw in place.
Then POP and SLIDE in place!
Step 7: Transfer/Move Location
If you are moving to a different location or gifting to a friend or family. These are the things you need to check and change. Everything you need to connect to network
SSID PASSWRORD IP ADDRESS RANGE
interface wlan0
update_config=1
country=us
network={
ssid=""
psk=""
key_mgmt=WPA-PSK
sudo reboot
That is all the changes you need to make.
ENJOY!
Step 8: Final
Can be placed ANYWHERE!
LOOKS AMAZING!
