Introduction: Wild Life Snail Tutorial
About: Hi, I am TripleCcosplay. I am a 3d Modeler and cosplayer, with a focus on props
Hi after some time I have finally made the tutorial for the Wild Life Snails. Now before we go through the tutorial I have two requests from you as the reader.
  1. If you end up making a snail using these files/tutorial, please tag me with TripleCcosplay, not be cause I want the fame or fortune. It's because I wanna see what people do with my creations. I want to see people take my ideas and make them their own.
  2. These tutorials and files will always be free, no matter what. I was once a young upstart cosplayer who didn't have the money to pay for files, or templates or tutorials, and I believe that pay-walling things like this can kill the hobby for people before they begin. However, these tutorials do take time, and energy. If you have the funding and would like to donate I do have a Ko-Fi here, https://ko-fi.com/tripleccosplay. However I will never require it and it is only if you are willing.
Now with that all out of the way on to Tutorial.
  1. 1 Roll of 3D printer Filament
  2. Sandpaper (60 Grit, 220 Grit, and 400 Grit)
  3. 6: 12x8 Sheets of Thin Balsa Wood: https://www.amazon.com/dp/B07NWLC7LV?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
  4. RC Car: https://www.amazon.com/dp/B0BZHDW4KZ?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
  5. 1 Mini Speaker: https://www.amazon.com/dp/B0CY7NP5MW?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
  6. Acrylic Paint (Colors Depending on which Snail you are doing)
  7. Masking or Painters Tape (Optional)
  8. Super Glue (I personally use Loctite Gel Control Super glue, but it is a preference).
  9. 5 AA Batteries
  10. Wood Filler
Tools.
  1. 3D Printer (I am personally using a Bambu Lab A1)
  2. Paintbrushes
  3. Pliers
  4. Exacto Knife, or Sharp Box Cutter
  5. Small Phillips head Screw Driver
  6. Wire Cutters
  7. Pencil
Step 1: Printing All Files
First you are going to print all needed files. I currently have them listed on both Thingiverse.
https://www.thingiverse.com/thing:6928679
and Maker World.
https://makerworld.com/en/models/1046888.
When printing the files there will be two head models. 1 is for the normal snails and one is for a quiz bot snail. They have different head shapes and required two different files. However this tutorial will be making a Gary Snail.
As well I personally recommend printing everything at 15% Infill, except for the heads which you need to print at 10% Infill or less or the snails will be too front heavy.
NOTE: If you are printing a quiz bot snail. I would recommend printing the head at 5% and even with that you will still probably need to add some weight inside the shell for the snail to be able to drive.
Step 2: Assembling and Cleaning the Body Prints
What you will first want to do is clean out all of the support material on each print. I recommend doing this with a sharp exacto knife and a pair of needle nose pliers.
With all files printed and supports removed we can now start assembling the body of the snail. All we are going to do is just put the body and the head piece together, with a small bit of super glue in each hole on the head.
Now that they are attached you will probably notice a small gap in between these two pieces. We are going to fix that will a small amount of wood putty. Apply it to the body so that it fills the gap, and try to remove as much excess as possible so we have less to sand after.
Once the putty is dry we can now go ahead and clean the 3d prints. Besides the wood putty, 3d prints will almost always have print lines, and they don't look great on props. All you are going to do is go over each visible piece (note that means no shell pieces) with a round of 60 Grit Sand paper, 220 Grit Sand paper, and 400 Grit Sand paper. You will want to do this until you have removed as much of the print lines as possible and gotten everything nice and smooth.
Once everything is nice and smooth we will go ahead and set the body aside for now, and focus on the shell.
Step 3: Shell Frame Assembly
Now that we are done with the body we will move on to the shell of the snails.
First we are going to assemble the shell frame. Like what we did the shell body we are going to assemble the frame with a bit of super glue in each of the holes.
Once the shell is assembled, you are going to then cut your balsa wood sheets into 6 panels at these measurements.
2: 7.125 x 7.125in
2: 7.125in x 7.25in
2: 7.25in x 7.25in
Now that we have our panels cut we are going to assemble the shell.
Step 4: Shell Assembley
First, we will take our two 7.125 x 7.125in panels and put them on opposite sides of the frame. I recommend gluing the panels on with super glue. You well then wanna take some 60 grit sand paper and sand the edges down so they are flush with the sides of the frame.
We will repeat this step for the 7.125 x 7.25in panels as well, but you will want to place them so that they cover the edges of the 7.125 x 7.125in Panels. Now we have a nice box with the top and bottom missing.
What we are going to do is now cut a 2.75in square in the center of one of our last remaining panels. This will be your bottom panel, and will allow for the shell to slide around the audio holder in the center of the snail body.
Repeat the same step for the last two panels for attaching and sanding, and we will be left with a mostly completed shell.
Step 5: Cleaning Shell
Something you might notice is that there are some gaps on the edges of your shell. This will happen if you have cut your panels perfectly or your frame pieces might have warped. Thankfully this is super easy to fix. All you need to do is fill those small gaps with some wood putty. We will follow the same steps we did in step 2, and once done we will have a ready to paint Shell and Body.
Step 6: Drawing Lines/Marking Colors
So on these snails one pixel is equal to 23mm x 23mm. So what I do is mark out each 23mm and then draw lines to make the "pixels". Note: If you are making a shell with especially light colors (think reds, and yellows) make sure lines are as light as possible. As covering them with paint takes so many coats. Also you don't have to do this step but I recommend it as it makes life a lot easier.
Step 7: Taping and Painting
If you want to have crisp clean lines I highly recommend using either masking tape or painters tape to get those nice lines. However you do not have to do this step either it's only if you want.
For painting I honestly just use some cheap dollar store acrylic paint, that match the color the closest, and mix colors when needed.
Step 8: Disassemble RC Car
Now that our snail is painted we get to do the fun part, making the snail move. All you need to do is remove the four highlighted screws. This will allow you to almost all of the excess plastic. There should then be two LED's attached, you can cut off the red and white wires attached to them, but make sure you cut no other wires, as they control the car.
Step 9: Attach RC Car
Finally we can put in out two RC support bars, we will want to glue these to the frame. so that they do not move. Make sure the one labeled front goes towards the head, and the one labeled back goes towards the tail.
Step 10: Speaker and Audio
Finally if you want to have some lovely sound noises, we can put our small speaker in the box. and close it up with our lid. If you are looking for audio feel free to use the audio listed below, but note it is just some lightly edited audio, and if you want the snippets you will need to edit the audio your self.
Step 11: DONE
Congratulations! We've made it to the end and now you have a fully completed snail! One final note, your snail might be a little front heavy, which is fine. To fix this all you need to do is put a small amount weight in the back of the shell to counterweight it.
Thank you for following my tutorial, and I hope you have a wonderful time making murder snails.
-TripleCcosplay
