Introduction: Window Pot
Soo... i love plants - the green ibn my eyes gives me good feeling.
So in my bathroom, i have a small window, and as you guess, it needed some decoration - soo here goes another pot planter
Step 1: Cut the Frame
I user an old MDF parquet floor that i found on the street.
Although it`s not the best ( or at all ) material to use for pots ( since u use water and it can swell up )
But i found a solution - cover the internal body with nylon - and your protected
Step 2: Drill Holes for Drainage
A well known rule! every pot needs a good drainage in order to survive.
So drill a few holes in the bottom for all the water to go away quick
Step 3: Gluing Time!
I used the Titebond glue.
Very strong !
Step 4: Hold It Tight!
Attach the sides and hold it tight using clamps!
Leave it like this for 24 hours !
Tip:
I sanded a bit with sanding paper the sides ( where i applied the glue ) since the surface of the MDF is tricky to glue- after u sand it, it is much granulated.
Step 5: Create Legs
You need a bit of "space" between it and the ground that it sits on - so i created small legs for it to stand on
Step 6: Start Planting
Pick your favorite plants and plant it
Hope u enjoyed - it came out great
