Introduction: Window Shutters
Make your own wood window shutters for a lot less...and easy too!
plywood approximately 1/4" thick
table saw (or Skill saw)
measuring tape
piano hinge
metal snips
jeweler's saw (or Dremel)
ball pein hammer & metal block (optional)
patina (optional)
torch (optional)
drill (or drill press)
drill bits
lubricant
rivets
rivet gun
stain
Step 1: Cut Your Hinges From a Continuous Hinge (Piano Hinge)
I chose to make a butterfly shape hinge from a continuous (Piano) hinge, basically cutting the existing hole out, but you can be creative and make any shape you want as long as you have enough hinge segments.
Step 2: Separate the Hinge Segments by Using a Jeweler's Saw or Dremel Tool
Step 3: Trim Off the Excess Using Your Snips
Step 4: Planish With a Ball Pein Hammer, If You Desire
Step 5: Straighten Out the Hinge by Hammering Front, Back and the Hinge Itself to Insure It Is Working Friction Free.
Step 6: If You Want to 'antique' the Hinge, Put It Under a Torch, or Add a Patina Like Liver of Sulphur
Step 7: Sand Some of the Patina Off With an Abrasive. I Like to Use a Scotch Bright Pad. the Patina Stays in the Recesses.
Step 8: Drill Your Holes. I Made a Jig to Hold the Hinge Making It Easier on My Fingers. Use a Lubricant to Save the Life of Your Drill Bit. Then Either File Off the Excess Metal on the Backside or Hammer (faster)
Step 9: Measure Your Window, Figure Out the Width and Height of Your Shutter Slats, Then Cut Using Either a Table Saw or a Skill Saw. It's Ok to Not Be Perfect As the Look of These Are Reminiscent of Barn Siding.
Step 10: Measure and Mark Where You Will Be Mounting the Hinges.
This window is 69" x 69" so I cut my slats at 4 3/16" intending to have two sets of shutters that open. Start with hinges on a outside board, then skip one, etc. (...because you will be mounting hinges on the backside so that it will accordion together.)
Step 11: Rivet Your Hinges by Using a Rivet Gun and the Appropriate Size Rivet. I Like to Use Aluminum Rivets As It Is Easier on the Hands, However, You Can Find Beautiful Copper and Brass Rivets.
Tip: only drill one hole at a time, secure rivet, then on to the next. This helps keep things true. Keep rivet gun butted up close to the hinge. 2 or 3 pumps will snap it off. You can also use small bolts and nuts if you wish.
Step 12: Be Creative! Use Your Imagination...here Is an Example of Different Looks. Enjoy!
