Introduction: Windows Update Error 8000FFFF
If you receive Windows Update error 8000FFFF, it means that there are Windowsregistry values that are blocking the update from being downloaded and installed.
You can run a troubleshooter that will automatically find and fix some common problems with Windows Update, or fix the problem manually.
To fix this problem manually:
1. Open the Registry Editor by clicking the Start button , typing regedit into the Search box, and then pressing ENTER. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
2. In the left pane, find and double-click HKEY_LOCAL_MACHINE, and then click COMPONENTS.
3. Right-click COMPONENTS, and then click Export. By default, this file is saved to your desktop, but you can choose any folder.
4. In the File Name text box, type COMPONENTS. You have now created a back up copy of the registry values you're going to be removing.
5. In the right pane, search for PendingXmlIdentifier, right-click it, and then click Delete. PendingXmlIdentifier might not be listed.
6. In the right pane, search for NextQueueEntryIndex, right-click it, and then click Delete. NextQueueEntryIndex might not be listed.
7. In the right pane, search for AdvancedInstallersNeedResolving, right-click it, and then click Delete.AdvancedInstallersNeedResolving might not be listed.
8. Restart your computer and then run Windows Update again.
PS: If you need to restore the registry values you modified, double-click the COMPONENTS.reg file on your desktop, and then follow the steps. If you are prompted for an administrator password or confirmation, type the password or provide confirmation. You can delete this file once you are finished with it.
NOTE:This method is applies to Windows Vista.
Error codes this applies to:
WindowsUpdate_8000ffff, 0x8000ffff, 8000ffff
