Introduction: Wine Bottle Jack-o-lanterns
Halloween + drinking = wine bottle jack-o-lanterns!
Turn regular cheap wine bottles into some funky Halloween decorations. Halloween decorations that you can drink! Even better.
This Instructable was brought to you by Krylon
Step 1: Materials
- Cheap wine. Charles Shaw is always a winner here. $2 a bottle at Trader Joe's
- Masking tape
- Sharpie
- X-acto knife
- Spray paint. Definitely need orange, green is optional.
- Bucket
Step 2: Ditch Those Labels
Soak the bottles in a bucket of water for a little while and then peel and scrape off the soggy mess. This only took about 10-15 minutes, I think. I actually forgot about them on my front stoop for a bit. I'm an awesome neighbor.
Step 3: Tape It Up
Break out the masking tape! Put a large working are on the front of the bottle. The "front" here being the side facing you when the seams of the bottle are pointing to the side.
Also wrap a bit of tape around the top of the bottle to avoid painting the cork and lip of the bottle.
Step 4: Draw Faces!
Use the Sharpie to draw some Halloween faces on the bottles. Have fun with this step, it's better to be loose and see what you make.
Step 5: Cut and Peel
Use the X-acto to cut the edges of the faces you just drew. Make sure to get all the way around. Then just peel away everything else, being careful not to go too fast. You may have missed a spot and don't want to go back.
If you do mess up and tear the tape, you can patch it with a bit more masking tape. That's what happened to the happy face on the right.
Step 6: Paint the Stems
Break out the green spraypaint and spray the necks of the bottles. Wait a while, at least a day, before applying some masking tape over these to protect them for the next stage. Do it too early and the tape will pull off some of the paint when it's removed.
Step 7: Paint the Bodies
Now use the orange spraypaint and apply a series of light coats with 20 minutes in between to let each coat dry.
Once you're done, let the bottles dry for at least an hour before removing any of the tape.
Step 8: Peel Off and Enjoy!
Slowly remove all of the tape and you have some wine bottle jack-o-lanterns! While these bottles are dry to the touch they may still be a little tacky and smell like spraypaint. Let them fully dry for a few days, or even a week, before putting them out or giving them to someone else. No one likes a smelly present.
Finally, don't hesitate to drink them, fearing that you'll ruin the look. They still look good even when empty.
Enjoy!
Halloween Food Challenge
Halloween Decorations Challenge
33 Comments
11 years ago on Step 8
The paint doesn't stick to the bottle do you have any sugestions
Reply 11 years ago on Step 8
Did you do a light coat? Make sure the glass is clean and do a very light coat of paint first. Be sure to wait for a while for it to dry and repeat the process. If you try to do it all at once it'll drip off.
Reply 7 years ago
Would a light sanding with rough sandpaper work to better make the paint stick along with light coats? I want to make some of these today before my daughter and grandaughter fly back home. Id like them take one with them. They are too cute and your instructions are so easy. Thanks.
10 years ago on Step 8
It would also be cool if you put some Christmas lights inside!
10 years ago on Step 2
Ethanol actually works pretty well for removing wine labels too.
Reply 10 years ago on Step 2
True, but water comes out of my faucet :)
11 years ago on Introduction
Never Drink & Spray.
Christmas is coming, you can go on full Santa mode and paint candy cane bottles.
Reply 11 years ago on Introduction
Nice! I'm already planning a few Xmas versions. Just might have to use that candy cane one as well. :)
Thanks for the instructable. Since I was already drunk after two wine bottles, I decided to also follow the candy corn bottle instructable: http://swelldesigner.blogspot.com/2011/09/candy-corn-bottle-vases.html
Ooh, nice pairing
Thanks for this ibble... I really enjoyed making these :-)
Hey! Nice job!
Clever. When I first saw these, I figured you had started with CLEAR glass bottles and painted from the inside in reverse order (eye/mouth/nose 1st then, orange).
You still have a great recycling idea.
Why not paint the bottle with the orange paint first then wrap bottle with painters tape and then cut out designs and paint designs?
Then you're painting twice instead of once.
You could drop a glow stick into them and set them out for Halloween.
Great idea! I was racking my brain trying to figure out how to light it up. Thanks!
If you use white wine I wonder if it would look golden as if lit or of the orange behind would mess that up.... Hmmm. I may have to experiment.
Not quite sure, was just wondering a similar thing, but more about what it would look like empty. I'd be worried there there isn't enough light getting into the bottle with all the paint on it. Maybe with a thin enough layer, or if you only paint about two thirds of the bottle (leaving the back unpainted).
Love the idea of an LED too. Was thinking about a candle but there's always the risk of the glass breaking from the heat. Maybe a flickering/flashing LED stapped to some LR44 batteries so it can be dropped inside the bottle? You'd lose the Golden look you're after by emptying the bottle, but you could paint the 'face' or waterproof the LED circuit?
In a pinch you could drop a glow stick in there! Very low tech. :-)
