Introduction: Winterizing Boat Engines Is Easy Your Marine Engine That Is Fresh Water Cooled
This will show you the basics this can be applied to I4, I6, V6 and V8 Engines
Watch the video of every detail *******
Here is how I have been winterizing since 1999 without any issues
“As an Amazon Associate I earn from qualifying purchases.”
Shoreline Marine Bilge Pump https://amzn.to/3eiVwEQ
Seaworks Dual Feed Muff Style Boat Motor Flusher | Use for Antifreeze Winterization or Common Water Flush | 5/8 Inch Standard Garden Hose Connection (Black) https://amzn.to/3TV6P5H
Step 1: Warm the Engine
Use the muffs or back boat into the water if near by
Step 2: Drain the Engine
Turn Off Engine and Drain Water Out
Step 3: Bin Setup for Pink Antifreeze
Use the Bin, Muffs, Bilge Pump and the Battery in the boat or an extra one if you have it
Step 4: Run Engine on Pink Antifreeze
Run on the Pink Antifreeze Until it is low in the Bin DO NOT RUN IT DRY! You will damage the pump in the boat. Watch video to see details.
Step 5: Draining the Pink Antifreeze
Drain the Engine again as air is best to have in the engine, Do Not skip this step.
Check Out My other how-to videos
(615) My Two Good Hands - YouTube
