Introduction: Wire Scorpion
To start off, I am not claiming to have created this myself or be the first to post this info here on Instructables. The story behind me learning this art is not a long one. My supervisor at work has made these for quite some time. One day I was sitting at his desk looking at them and thought "I can make that". So I did.
After a few google searches I found that this is not a very uncommon thing to be able to make either. Like I mentioned earlier, another user posted a "Wire Scorpion" instructable a few years back.
Here is the URL: https://www.instructables.com/id/Wire-Scorpion/
My take is just slightly different. Take a look here and the other instructable and figure out what is best for you!!
Step 1: Supplies Needed
There aren't many supplies needed:
-Wire (I used 22 gauge, but any solid wire will do. The larger the wire, the bigger the scorpion)
-Pliers for help with bending and cutting
-Some sort of measuring utensil
If you are using 22 gauge wire, you will need 16 - 10 inch pieces. If you are using thicker wire, you will need longer pieces of wire.
Step 2: Build the Tail
This is one of the main differences between this and the other instructable here, how the tail looks. The great thing about this is that you can make it look however you'd like. I like mine segmented as it shows here. Start the first wrap and with each subsequent wire, add two additional wraps. For example, my first segment where I added my second wire started out with three wraps. Each additional wire also increased by two more wraps. 3, 5, 7, 9, 11, 13, 15, and 17.
Make Sense?
Make Sense?
Step 3: Add Wires for Body/Legs
You will take your remaining eight wires and wrap them one by one around your other wires. This will be "braided" to make the body of the scorpion (in the next step) and will then turn into the eight legs of the scorpion.
Step 4: "Braid" the Body
Take the furthest wire to the back of the scorpion (mine was on the left) and bring it across the top (to the right for me) and then under and back behind (behind the scorpion returning it to the left side).
Repeat and alternate for every wire till you finish all 16 wires (eight on each side of the scorpion).
Step 5: Twist Wires to Form the Legs
Now take your 16 wires and twist them together two at a time to form your scorpions legs. Try to twist them so they turn out evenly twisted all the way to the end.
Step 6: Form Pincers and Mouth
Now it's time to form your scorpion's pincers and mouth. You should have eight wires coming out this end of your scorpion. Form the bottom four into your scorpion's pincers. Remove (or keep) two of the wires in the middle (you can keep them if you'd like four wires for the mouth instead of just two. The scorpion pictured had the two wires removed).
Step 7: Shape, Form, and Cut Legs
The last thing you want to do is to shape and form the legs to the desired shape. There isn't anything right or wrong here, just whatever you like best.
Step 8: Final Product
This is the final product. This particular scorpion measures about three inches tall and three inches long with a tail that is about five and a half inches long. It's a fun project that is easy to make, cool, and doesn't take too long to build.
