Introduction: Wire Straightener / Drahtrichtgerät
Do you speak German? Further down you will find the instructions in German. (Weiter unten findest Du die Anleitung auf deutsch.)
Hi, I'm Martin, do you have a wire that has many kinks and is therefore not easy to work with? Here is the solution! This wire straightener straightens your bent wire by simply pulling it through it once. You can easily recreate this simple device at home. The wire straightener has some outstanding advantages (besides the fact that it naturally removes every kink from your wire;)):
- The application is very uncomplicated and very fast (thanks to the swivel mechanism, wires can be inserted very quickly; in addition, the individual rollers can be quickly adjusted if necessary)
- many different wires can be straightened (steel up to 1.2 mm in diameter, copper and aluminum anyway, stainless steel did not work so well)
- very cheap to produce
What do you need for it?
These are the tools you need:
- craft knife*
- Allen key*
- small slotted screwdriver*
- flat nose pliers*
- 3D printer* (you don't have it? No problem! Just order the 3D printed parts here*!)
Do you have all the tools? Yes? For sure you are interested in what you need for components.
I once wrote everything down to give you an overview. Most of the parts are linked so that you don't have to search for them. The links are so-called affiliate links. These are a fine invention, because if you click on them, I get a small commission, although you pay exactly the same price as usual. So if you like my instructions and are wondering how you can appreciate these instructions, then click on the link and order the parts afterwards. If the whole thing is still tremendous for you with these affiliate links, then you can find out more about them here, for example. I am very happy and would like to say thank you very much in advance!
But now really to the parts list:
- approx. 55g filament PLA* for your printer (if you order the parts in my shop, then of course you don't need the filament;)); 1x lower_part, 1x upper_part, 6x spacer
- 7x ball bearings with V-groove*
- 4x wing nut M4*
- 4x washer M4*
- 4x hexagon screw M4x30*
- 5x locking nuts M4*
- 5x pan head screw with hexagon socket M4x20*
I hope you enjoy the step-by-step instructions!
Your Martin
* = Advertising/Werbung
-----------German/deutsch-------------
Hi ich bin Martin, hast Du einen Draht der viele Knicke hat und somit nicht gut zu verarbeiten ist? Hier ist die Lösung! Dieses Drahtrichtgerät begradigt Deinen verbogenen Draht, indem Du ihn einfach einmal hindurchziehst. Dieses simple Gerät kannst Du ganz leicht zuhause nachbauen. Das Drahtrichtgerät hat einige hervorstechende Vorteile (neben dem, dass es selbstverständlich jeden Knick aus Deinem Draht entfernt;)):
- Die Anwendung ist sehr unkompliziert und sehr schnell (durch den Schwenkmechanismus können Drähte sehr schnell eingelegt werden; zudem lassen sich die einzelnen Rollen bei Bedarf zügig justieren)
- viele verschiedene Drähte können begradigt werden (Stahl bis 1,2 mm Durchmesser, Kupfer und Aluminium sowieso, Edelstahl hat nicht so gut funktioniert)
- sehr günstig in der Herstellung
Was Du dafür brauchst?
Das sind die erforderlichen Werkzeuge:
- Cuttermesser*
- Inbusschlüssel*
- kleiner Schlitzschraubendreher*
- Flachzange*
- 3D-Drucker* (hast Du nicht? Kein Problem!Bestelle einfach hier* die 3D-gedruckten Teile!)
Du hast alle Werkzeuge? Ja? Dann interessiert Dich jetzt sicher, was Du alles für Bauteile brauchst.
Ich habe mal alles zusammengeschrieben um Dir eine Übersicht zu geben. Die Teile sind größtenteils verlinkt damit Du sie nicht erst lange suchen musst. Die Links sind sogenannte Affiliate-Links. Diese sind eine feine Erfindung, denn wenn Du darauf klickst, bekomme ich eine kleine Provision, obwohl Du genau den gleichen Preis wie sonst auch bezahlst. Wenn Du also meine Anleitung gut findest und Dich fragst, wie Du diese Anleitung wertschätzen kannst, dann klicke doch ganz bewusst auf den Link und bestelle die Teile im Anschluss. Wenn Dir das ganze noch ungeheuer ist mit diesen Affiliate-Links, dann kannst Du Dich beispielsweise hier darüber informieren. Ich freue mich sehr und sage Dir jetzt schonmal ein herzliches Dankeschön!
Jetzt aber wirklich zu der Teileliste:
- ca. 55g Filament PLA* für Deinen Drucker (wenn Du die Teile in meinem Shop bestellst, dann brauchst Du das Filament natürlich nicht;)); 1x lower_part, 1x upper_part, 6x spacer
- 7x Kugellager mit V-Nut*
- 4x Flügelmutter M4*
- 4x Unterlegscheibe M4*
- 4x Sechskantschraube M4x30*
- 5x Sicherungsmutter M4*
- 5x Flachkopfschraube mit Innensechskant M4x20*
Ich wünsche Dir viel Spaß mit der Schritt-für-Schritt-Anleitung!
Dein Martin
Step 1: Print Parts / Teile Drucken
- download stl files (1x lower_part, 1x upper_part, 6x spacer)
- create G-code with slicer with the following parameters (layer thickness 0.2 mm, infill 25 %, see pictures)
- print out parts (1x lower part, 1x upper part, 6x spacer)
- clean parts
- stl-Files downloaden (1x lower_part, 1x upper_part, 6x spacer)
- G-Code mit Slicer mit folgenden Parametern (s. Bilder) erstellen
- Teile ausdrucken (1x Unterteil, 1x Oberteil, 6x Distanzscheibe)
- Teile säubern
Step 2: Assemble the Lower Part / Unterteil Zusammenbauen
- first mount both outer bearings, then both inner ones
- insert the bearing, insert the M4 locking nut in the hexagon socket, screw in the M4x20 pan head screw
- tighten the screw and loosen it again slightly if the bearing jams
- assemble all four bearings according to this procedure
-------------German/deutsch------------
- zunächst beide äußeren Lager montieren, dann beide inneren
- Lager einsetzen, M4 Sicherungsmutter in Sechskantaufnahme einsetzen, M4x20 Flachkopfschraube eindrehen
- Schraube anziehen und bei Blockieren des Lagers wieder leicht lösen
- alle vier Lager nach diesem Vorgehen montieren
Step 3: Assemble the Upper Part / Oberteil Zusammenbauen
- insert the M4x30 hexagon screw from the side with the
hexagon socket halfway
- slide a spacer onto the screw
- insert the bearing and pick it up with the screw
- insert the second spacer and push the screw through completely
- screw on the M4 wing nut with the M4 washer
- assemble all three bearings according to this procedure
------------German/deutsch-------------
- M4x30 Sechskantschraube von der Seite mit der
Sechskantaufnahme bis zur Hälfte einstecken
- eine Distanzscheibe auf Schraube aufschieben
- Lager einsetzen und mit der Schraube aufnehmen
- zweite Distanzscheibe einsetzen und Schraube vollständig durchschieben
- M4 Flügelmutter mit M4 Unterlegscheibe aufschrauben
- alle drei Lager nach diesem Vorgehen montieren
Step 4: Joining the Upper Part and the Lower Part / Oberteil Und Unterteil Zusammenfügen
- on the side where the arrows in the lower part point to
an M4 lock nut is inserted into the only remaining hexagon socket
- the upper part is inserted in the middle of the lower part so that the M4x20 flat head screw can be inserted
- tighten the M4x20 flat head screw and the already inserted nut and loosen it again slightly so that the upper part can still be swiveled
- insert the M4x30 hexagon screw through the last remaining hole on the side of the hexagon socket and lightly screw on an M4 wing nut with an M4 washer
Have fun with your wire straightener and good luck with your projects!
Your Martin
- Auf der Seite, wo die Pfeile im Unterteil hinzeigen wird
eine M4 Sicherungsmutter in die einzig verbleibende Sechskantaufnahme eingesetzt
- Oberteil wird mittig in das Unterteil eingeführt, so dass die M4x20 Flachkopfschraube durchgesteckt werden kann
- M4x20 Flachkopfschraube und bereits eingelegte Mutter anziehen und wieder leicht lösen, so dass Oberteil schwenkbar bleibt
- M4x30 Sechskantschraube durch letztes verbleibende Loch von seitens der Sechskantaufnahme stecken und eine M4 Flügelmutter mit M4 Unterlegscheibe leicht aufschrauben
Viel Spaß mit Deinem Drahtrichtgerät und weiterhin viel Erfolg bei Deinen Projekten!
Dein Martin
