Introduction: Wire Tree Sculpture
A very good present for Christmas!
Step 1: Wire
4 little wires with insulation.
Step 2: Stripping
strip insulation of all 4 wires and the insulation on the 4 little wires
Step 3: Cut in Half
Cut stripped wire in half and then cut in half again so you have 4 wires of the same length.
Step 4: Twisting
Twist two wires together leaving some of the wire untwisted at the top and bottom.
Twist 2 at a time then once all wires are paired up do it again with another one until you don't have any more loose wire left.
Step 5: Add the V
Remember trees aren't perfect and usually have v's or something.
Redo step 2 except not as long and as much twist them as usual and then twist around tree and have it stick outwards.
Do that again but wrap around v spot so it looks more realistic (look at pictures)
Step 6: Your Done
Tweak it a bit to get it just right.
