Unpublished!​
36,167
279
36
Introduction: Unpublished!​
About: Thank you, Instructables!! I have removed many of my Instructables as along with being cringy :P they lacked proper documentation (thus difficult to replicate) and some didn't even work properly. Please enjo…
Unpublished!
Make It Glow! Contest
Tech Contest
Tech Contest
1 Person Made This Project!
  • Game Design: Student Design Challenge
  • For the Home Contest
  • Make It Bridge
    Make It Bridge
36 Comments
Dr.M3
Dr.M3
6 years ago
hey this is basically a slayer exciter, there are many tutorials on the internet on how to Make them. he should have used better components though. I know I use a tip31c trans npn and a 47k ohm res and 2 uf4007 diodes. along with primary and secondary coils. you should also use a cinductive metal ball at the tip for better results.
ARAVINDCHOWDARY
ARAVINDCHOWDARY
6 years ago
its trash dosent work
dont waste your time reading it
VivekS99
VivekS99
6 years ago
hey buddy i tried it but didnt work
what to do
wmada1
wmada1
7 years ago
i cant get it to work
Gursimran Singh 425
Gursimran Singh 425
Reply 7 years ago
Hi, thanks for commenting you can post some pictures of your circuit that you made!! I think you might have overlapped coiling excessively or the transistor pins might be wrong!! Pleaae recheck everything!! Thanx :-)
SHOE0007
SHOE0007
7 years ago
What kind of Inductance would your coil emit and would a 710 turning coil damage equipment? PLEASE ANSWER ME SOON.
Daniel.
Gursimran Singh 425
Gursimran Singh 425
Reply 7 years ago
It is mutual induction and 710 turns may pr may not work it will not damage cfl in any case.:-)Best of luck!!
msingh74
msingh74
7 years ago
Hi friend I have also made mine tesla coil earlier , and it works great.
awesomevicky
awesomevicky
7 years ago
amazing project...I'll try to make it.
Dushyanta
Dushyanta
7 years ago
You would have named this instructable as "How to make a tesla coil".
Yonatan24
Yonatan24
Reply 7 years ago
A lot of people have made a "Tesla Coil" 'Ible = Less views...
keowee
keowee
7 years ago
A few years ago, Dept of Energy had a huge (maybe 100 ft in length) CFL bulb lightening the bottom of their building. At one end of this bulb was a small microwave box which excited this CFL. Was supposed to save energy and burn for a long time. As I remember it didn't burn very long before it stopped.
Dept of Energy
jck61
jck61
Reply 7 years ago
That sounds like it was a sulfur vapor lamp connected to a light tube to distribute the intense light it produced. It was supposed to be very efficient but only practical on a large scale. The Air and Space Museum had about half a dozen up near the ceiling. Unfortunately, they didn't last as long as expected, and the manufacturer went out of business.
jimmie.c.boswell
jimmie.c.boswell
Reply 7 years ago
well if you lose the partial vacuum inside of the bulb, it would not work. otherwise the microwave, could keep it lit as long as the microwave did not fail.
you can even use tesla coils, or neon transformers to run burnt out fluorescent bulbs.
BennyP5
BennyP5
7 years ago
Hi!
Joined a bit in advance just to ask this question:
If i would like to make a setup with a stronger effect, I assume that means a larger diameter/longer coil/more turns? Also is this a viable option as a night light, or should I concider making such a night light motion sensing?
jimmie.c.boswell
jimmie.c.boswell
Reply 7 years ago
well there are all kinds of ways, to increase the output and effect the a tesla coil. like winding the coil, on a ferrite core instead of an air coil. making sure, your ferrite is optimal for the frequency. which would make, the size if the coil needed smaller with better coupling.
increase the secondary, turns ratio and using slightly heaver tubing or litz wire for the primary autotransformer to increase amps and voltage in the primary. unless you are using a, isolated tesla coil.
increase the frequency, of the coil. frequency has an effect on distance the coil can arc, or radiate.
and another less likely for the layman, would be a super-conductor tesla coil. which i do not believe, has been researched as of today. but it would be, a new novel neet idea.
BennyP5
BennyP5
Reply 7 years ago
With increasing the turnratio, you mean secondary:primary right? I happening to have a pretty heavy-duty transformer on hand, so maby thats my approach. My plan is to hide the coil and make a "magic" lamp so it needs to stay relatively small, and I dont have ferrite on hand :D on the other hand, the transformer I have is impossible to hide in the object I had in mind.....
