Introduction: Wireless Charging Desk With Metal Inlay
In this Instructable I'll show you how I made this computer desk with wireless charging. I did a lot of metal work on this one including a metal base and a copper metal bowtie inlay.
Be sure to watch the video above, and if you like it please subscribe to my YouTube channel!
And if you like the Instructable please vote for me for the Metalworking Contest at the end of the post!
Step 1: Gather Tools and Materials
Tools Used (affiliate links)
Materials/Supplies
- Wireless Charging Pad
- 2:1 Clear Epoxy
- 1" 11ga tube steel
- Walnut hardwood
Step 2: Prepare the Walnut Top
For the top I used some walnut boards I got off Craigslist. I cut them to size then ran them through the milling machines and table saw to get them ready for the glue up.
For the first glue up I glued two panels of two boards together. After the glue was dry I filled the knots and holes in the wood with epoxy.
I cleaned up both sets of boards then did my final glue up to join all four boards together for the top.
Step 3: Cut the Inlay for the Wireless Charger
The wireless charger is inlayed into the underside of the top of the computer desk.
I traced the charger on the underside of the top then cut the recess with out with a router. I spaced the final pass of the router using a small 1/8" piece of scrap. This let the wood be thin enough for my specific charger to send the signal through the wood.
I did a test fit of the charger and installed it with hot glue into the cavity.
Step 4: Inlay the Copper Metal Bowtie
To add a killer feature accent and a way to tell where the wireless charger was placed I used a copper metal bowtie. It's about 4" long and 1/4" thick.
I marked the outline of the bowtie with a razor blade to establish the cut lines for the inlay.
Then I removed the bulk of the material with a router bit set to the depth of the bowtie. I finished the final recess by chiseling to the line I marked with the razor.
I used some epoxy to secure the bowtie into the recess and it was a great fit.
Step 5: Make the Metal Base
The metal base is 1" 11ga square tube. I had the pieces cut to size and then MIG welded them into a minimalist base.
I welded the ends of the desk first into two rectangles and then connected them with the stretchers to form the shape of the base.
This was only my second time welding and I'm not great but still learning a ton.
Step 6: Add the Top Clips and Finish the Base
To secure the top to the base I made some clips from 1" angle iron.
I drilled 6 holes in the angle iron spaced out about 1.5". Then I cut them apart with a grinder into 6 individual clips
I turned the base over and welded each clip to the top of the base.
Then I finished off the base by painting it matte black after spraying on some self etching primer.
Step 7: Finish the Top
After the bowtie epoxy was dry I sanded the top including the metal inlay. It took a long time to sand down the inlay even using 60 grit, so I'd suggest setting it lower than the wood.
I put on 2 coats of an oil based polyurethane that really made the top pop.
Step 8: Attach the Top to the Base
When the top was dry I flip it over and put the base on top and secured it with screws.
This thing turned out amazing and I really love having the ability to charge my phone on my desk with no wires. And that copper bowtie is a real stunner.
And if you like the Instructable please vote for me for the Metalworking Contest!
