Introduction: Wireless Robot V2 (Support WiFi & Bluetooth)
Step 1: Car Structure
I get The motors ,gear box and tires from two broken car kids toys from Scrap market nearby , they cost me about 10$ and I connect them using din rail and plastic as shown in the pictures.
Step 2: Connection Digram
Using the Serial pins of ATMEGA16 MCU is The Concept of this circuit and it consist from :
1- H-Bridge Motor driver using two L298.
2- Atmega16 MCU.
3- LEDs Driver using ULN2003.
4- Serial Bluetooth Module.
5- Serial-To-Ethernet converter.
6- WiFi Wireless access point.
7- Easy N surveillance IP cam.
8- 12 Volt battery with 7809 & 7805 voltage regulator for router and IP cam .
9- 6 Volt Battery for motors.
2- Atmega16 MCU.
Step 3: H-Bridge Circuits
two L298 dual H-bridge driver connected as shown in the pictures .
the motors working on 6 volt with 2.4 Amp. maximum current for each.
L298 Data sheet attached.
Step 4: LED Driver
ULN2003 Darlington transistor arrays is a fast solution and provide 7 output.
The circuit shown in attached picture.
Datasheet attached.
Datasheet attached.
Step 5: Controller Circuit
The source code debugged by ATMEL AVR studio 4 with AVR MKII ISP .
The Scenario of the code depending on:
1-Enabling the RX/TX of ATMEGA16 MCU.
2-Sending the ASCII code from the PC or Tablet .
3-Translate the ASCII code by the MCU to a specific output in port A and port C.
The fuse bit for 16 Mhz external frequency resonator should be set to :High: 0xC9 , Low: 0xFF as shown in the attached picture.
Code:
ATmega16 16MHz external frequency resonator
Baud Rate 9600 No Parity,1 Stop Bit,Flow Control:None
#include <avr/io.h>
#include <inttypes.h>
#include <util/delay.h>
void USARTInit(uint16_t ubrr_value)
//Set Baud rate
UBRRL = ubrr_value;
UBRRH = (ubrr_value>>8);
UCSRC=(1<<URSEL)|(3<<UCSZ0); // Set Asynchronous mode,No Parity ,1 StopBit
UCSRB=(1<<RXEN)|(1<<TXEN); //Enable The receiver and transmitter
char USARTReadChar()
while(!(UCSRA & (1<<RXC)))
// do nothing
return UDR;
void USARTWriteChar(char data)
while(!(UCSRA & (1<<UDRE)))
//do nothing
UDR=data;
void main()
DDRC=0xff;
DDRA=0xff;
char data;
USARTInit(103); //for 16Mhz and baud 9600 UBRR = 103 and for baud 19200 UBRR = 51
while(1)
data=USARTReadChar();
if (data==0x71){PORTC=0b10000000;USARTWriteChar('Q');} //q in ascii
if (data==0x77){PORTC=0b00001001;USARTWriteChar('w');} //w in ascii Forward
if (data==0x65){PORTC=0b01000000;USARTWriteChar('e');} //e in ascii
if (data==0x61){PORTC=0b00000011;USARTWriteChar('A');} //a in ascii Left
if (data==0x73){PORTC=0b00000000;USARTWriteChar('s');} //s in ascii Stop
if (data==0x64){PORTC=0b00001100;USARTWriteChar('d');} //d in ascii Right
if (data==0x7A){PORTC=0b00100000;USARTWriteChar('z');} //z in ascii
if (data==0x78){PORTC=0b10000110;USARTWriteChar('x');} //x in ascii Backward
if (data==0x99){PORTC=0b11110000;USARTWriteChar('c');} //c in ascii
if (data==0x69){PORTC=0b00001001;_delay_ms(200);PORTC=0b00000000;} //i in ascii Forward
if (data==0x6A){PORTC=0b00000011;_delay_ms(200);PORTC=0b00000000;} //j in ascii Left
if (data==0x6C){PORTC=0b00001100;_delay_ms(200);PORTC=0b00000000;} //l in ascii Right
if (data==0x6B){PORTC=0b00000110;_delay_ms(200);PORTC=0b00000000;} //k in ascii Back
if (data==0x31){PORTA=0b00000001;USARTWriteChar('1');} //1 in ascii //2 LED On
if (data==0x32){PORTA=0b00000010;USARTWriteChar('2');} //2 in ascii //4 LED on
if (data==0x33){PORTA=0b00000111;USARTWriteChar('3');} //3 in ascii //6 LED on
if (data==0x34){PORTA=0b00001000;USARTWriteChar('4');} //4 in ascii //Red LED on
if (data==0x35){PORTA=0b00010000;USARTWriteChar('5');} //5 in ascii
if (data==0x36){PORTA=0b00100000;USARTWriteChar('6');} //6 in ascii
if (data==0x37){PORTA=0b01000000;USARTWriteChar('7');} //7 in ascii
if (data==0x38){PORTA=0b10000000;USARTWriteChar('8');} //8 in ascii
if (data==0x39){PORTA=0b00000000;USARTWriteChar('9');} //9 in ascii //All Off
else {}
Code:
#include <avr/io.h>
//Set Baud rate
UBRRL = ubrr_value;
// do nothing
return UDR;
//do nothing
UDR=data;
void main()
DDRC=0xff;
DDRA=0xff;
char data;
while(1)
else {}
Step 6: Serial to Ethernet Converter
I get the module from below website :
http://en.usr.cn/USRCN/RS232-serial-to-ethernet-converter-tcp-ip-module
Connect:
VDD to 5 Volt.
GND to negative.
RX to TX of ATmega16.
TX to RX of Atmega16.
CFG :Normal Mode when connected to positive , Configuration mode when connected to negative.
Also RS232 to TTL module required to configure this module .
You can download all the documents from the mentioned website.
For this Project I configure the setting for the converter as below:
Work Mode : TCP/IP clinet.
Module IP : 192.168.1.2
Subnet Mask:255.255.255.0
Default gateway :192.168.1.1 (Access point IP).
Parity/data/stop :None /8/1
Destination IP :192.168.1.3 (Laptop IP).
Destination Port: 8234.
Baud Rate : 9600
Connect:
VDD to 5 Volt.
GND to negative.
Baud Rate : 9600
Step 7: Com-Redirector Software
Com-Redirector software used to create Virtual com in the Laptop because there is no direct physical connection to the laptop ,you can also use virtual serial ports emulator software from http://www.eterlogic.com/Downloads.html
Putty or hyper terminal software can be used to send information through this virtual serial port.
please watch the video for more information .
Step 8: Serial Bluetooth Module
I get the Slave Mode Serial Bluetooth module from below web site(all document included):
Pass Key:1234
http://www.elechouse.com/elechouse/index.php?main_page=product_info&cPath=90_91&products_id=603
About the software you can download android Bluetooth Controller software from android market ,its amazing software and easy to use.
https://play.google.com/store/apps/details?id=apps.BT&hl=en
Step 9: Switch Selector
in the end I connect a selector switch to select the wireless mode (WiFi or Bluetooth).
