Introduction: Wireless Security Cam
Step 1: You Need
Container (I use a old dominoes tin but any will do)
A phone with wifi compatibility (I used a blackberry 9300 model)
And the charging cable
(I used the factory USB that came with the phone connected to a USB to house power)
Step 2: Make the Product
Drill a hole the reason I didn't say you need a drill is because you can use a screw driver to make the hole use what you want
Note it must allow the wire to go through the tin
Step 3: Software Needed
I used mobiola webcamera but you can use any I use that because it is the best that I know that works on a blackberry
Step 4: Test It Out
Put a hole for a camera and you are done test it out and you are done
