Introduction: Wireless Turtle Beach Headset on XBOX ONE
Many of you know that the old XBOX 360 Controller is different from the XBOX ONE. Due to that, all the wireless headset adapters for Turtle Beach and Tritton won't work. Turtle Beach has stated "Xbox One uses proprietary technology that only Microsoft can produce and manufacture. We have no control over this." So as frustrated that i am for paying $300 for the Turtle Beach Tango, I decided to take action and make something work to get my headsets up and running. Here are the steps that I took, total cost is under $20 if you have some of the parts already.
PART NEEDED (Items marked FREE are parts I already had):
1ea - ($0.10) - 510ohm 1/8 watt resistor
1ea - ($0.16) - 820ohm 1/8 watt resistor
1ea - ($0.50) - LM317T
1ea - ($4.68) - mini board (Cut later)
1ea - ($5.99) - USB Mini Jack (Pack of 10)
1ea - (FREE) - USB cord (4") (you can also use a female mini jack and solder to the board, plan to do that on the next one I make)
1ea - (FREE) - 360 "AA" Battery Pack (Purchase 3 for $3.99)
1ea - (FREE) - Turtle Beach Bluetooth Puck (one you already have for the 360)
1ea - (FREE) - Broken 360 Controller (optional)
1ea - (FREE) - XBOX ONE Chat Headset
1ft - (FREE) - 26ga wire (Took from old PC)
TOOLS NEEDED:
Solder Iron
Solder w/flux
Wire strippers
Hot Glue Gun
Safety Torx T8 (disassemble 360 controller)
Torx screwdriver (XBOX Chat headset – quite small).
Step 1: Dismantle 360 Controller
- Take the old 360 controller apart (Safety Torx T8)
- Remove the bottom connector where the chat adapter plugs in.
Step 2: Dissemble XBONE Chat Headset
- Take the XBONE Chat Headset apart. (Torx Screws)
- Remove wires from the 4 pads. (Don't overheat!)
- Drill small hole for 3 wires to come out as shown. You will need to trim the bottom cover a bit to prevent it from pinching the wires.
- With the wires running out the hole as shown, Solder XBONE MIC to 360 connector Pin A4
- Solder XBONE HPL to 360 connector A2
- Soldier XBONE GND to 360 connector A1
- Soldier XBONE GND to XBONE HPR (Jumper)
- Re-assemble the XBONE chat headset.
Microphone Ground [GND] (originally the bare wire).
Microphone Positive [MIC] (originally the white wire).
Speaker Ground [HPR] (originally the black wire).*
Speaker Positive [HPL] (originally the blue wire).
*Jump HPR to Mic Ground
Step 3: Soldier Directly to Puck (OPTIONAL)
- Remove sticker from the bottom of the puck.
- Remove bottom cover by 2 TORX screws
- Remove front cover and drill small hole in front cover of the puck next to the audio jack for 5 wires to go through.
- Solder 3.3V to 3.3V Out on your PC Board
- Solder Power Ground to the Ground on your PC Board
- Solder MIC to MIC in the XBOX ONE Chat Headset
- Solder Speaker to HPL in the XBOX ONE Chat Headset
- Solder Ground to GND in the XBOX ONE Chat Headset
- *Jump HPR to Mic Ground
Step 4: Voltage to Puck
Use the this page as a reference for wiring the board and getting the voltage as close to 3.3 R1 = 510ohms
R2 = 820ohms
The chip should be facing you with the writing on it.
- VIN = 5V In
- ADJ = Goes to ground
- VOUT = 3.3V Out
Once you have the board wired up and have 3.3v (+/- .6v), then:
- Solder VOUT (3.3V) to 360 connector #4
- Solder Ground to 360 Connector #1
Step 5: Gut 360 Battery Pack
- Remove the quick release from the "AA" pack.
- Remove all metal from the pack
- Take dremel and remove the battery divider
- Insert the assembled pc board into the battery pack with the USB cable going out the front.
- Attach the all the pieces and test, everything should work!
- Once you test everything, you can hot glue your new adapter to the bottom of the XBONE chat adapter.
123D Circuits Contest
1 Person Made This Project!
- Vipor81 made it!
7 Comments
5 years ago
Or a 3.5mm male to 2.5mm female mic adapter lol
7 years ago
Thats creative..can you do the same thing for xbox one?
This is for the XBOX ONE. It's a conversion from the 360 to the ONE.
7 years ago
Also..not sure if there already is one,if there is i havent found it,i have been needing a bluetooth adapter that fits into the 3.5 jack of a stock car radio that i can both play music on and take calls
8 years ago on Introduction
The tritton so have are complete wireless. All I have is a base tht plugs into the back of the 360 via optical cable.
Would this work for the tritton 7.1 warheads as well?
I am not sure, if they used a "puck" that plugged into the 360 controller, then I would say yes.
