Introduction: Wiring the PIR
The PIR is an easy to use passive detector that uses Infrared to detect IR light from objects.There are only three connections to the Arduino.
These sensors can be used for motion detection, burglar alarms, night lights, or how about an automatic doorbell.
You can turn on a relay, a light, a buzzer, your TV or just about anything with these!
Step 1: Wiring and Code
Note: Check your pins on the PIR
Shown above
RED is Vcc
Black is Gnd
Yellow is Input
Here is the code:
Begin ============================================
/* This sketch uses a PIR sensor(Passive Infrared Detector) The output pin on the PIR is connected to Arduino Pin 2. When IR Motion is detected Arduino pin 13 will light. */
const int ledPin = 13; //This is the onboard LED
const int inputPin = 2; //input pin for the PIR
void setup()
pinMode(ledPin, OUTPUT); //LED on pin 13 will be an output
pinMode(inputPin, INPUT); //input from PIR
void loop()
int val = digitalRead(inputPin); //get the input value from PIR and place it into val
if (val==HIGH)
digitalWrite(ledPin, HIGH); //turn on LED if motion detected
delay(10); //wait
digitalWrite(ledPin, LOW); //then turn off LED
So depending on your use you could ring a doorbell when someone approaches (a visitor, the mailman, etc.) Perhaps as a night light or a burglar alarm for doors or windows. As this is basically a switch it can be used for tons of different things. Have fun and see what you can come up with! I would be interested to hear what you have made!
