An Arduino RSS Feed Display
Intro: An Arduino RSS Feed Display
This Arduino project will display RSS feed headlines on an LCD via an Arduino and a USB cable. It works quite well, and lets you keep up with the world news while you're sitting at your desk. Many of the values in the code can be changed, and the system can be adapted to display Twitter and other information as well. It uses Python to interface with the Arduino.
All of the code and instruction provided is done so with no guarantee of success. I've bugtested the code to the best of my ability, and it should work in most cases, but certain things can throw it off. Details of such are within.
STEP 1: Required Pieces/Parts for the Project
The project requires very few parts, generally things that most people with Arduinos will have lying around somewhere:
(1) Arduino Uno board
(1) Breadboard (I used a MakerShield prototyping shield instead, but a breadboard works just as well, albeit less compact)
(1) LED, your choice of color
(>12) Breadboard cables
(1) 16x2 Character LCD display, compatible with the LiquidCrystal library (works with larger LCD's with tweaking)
(1) Potentiometer, preferably 10K ohms.
(1) USB to USB-B cable (standard USB-to-Arduino cable)
STEP 2: Wiring Up the LCD and the LED
The LCD should be wired up as is shown in this picture (given it's a 16x2 LCD that uses the HD44780 driver). Potentiometer controls the contrast. It should also be noted that most LCD's use pins 15 and 16 on the LCD as the +5v and GND for the backlight.
Picture is from http://arduino.cc/en/Tutorial/LiquidCrystal. Make sure you test it using the "Hello World!" program described. The screen may need to have the contrast turned all the way up for it to display properly.
The LED just goes in digital pin 13 and the GND pin next to it. Make sure the polarity is correct (Longer leg should be the + leg, short legs goes to ground).
STEP 3: Getting the Required Software and Libraries
2 pieces of software and 2 Libraries/Extensions are needed for this project to work. The first library is an Arduino Library called LiquidCrystal440. It is available here: http://code.google.com/p/liquidcrystal440/. It is an updated version of the LiquidCrystal library, and helps deal with some issues when it comes to addressing memory that isn't currently visible on the screen.
Obviously to use the LiquidCrystal440 Library, you will need the first piece of software: The Arduino coding interface, which I assume all Arduino users have (if not, just check the Arduino.cc website)
The second piece of software you will need is Python. Python is an easy to learn programming language for the PC, Linux, or Mac. It is available for free here: http://www.python.org/.
The final thing you need is the extension that will let the Python computer program work with the Arduino itself, via the serial cable. The required extension is Pyserial, available here: http://pyserial.sourceforge.net/. Make sure you get the correct version of Pyserial to work with your version of Python (2.7 to 2.7, 3.1 to 3.1, etc).
STEP 4: The Arduino Code
// This code is for the Arduino RSS feed project, by Fritter
// Read the comment lines to figure out how it works
int startstring = 0; // recognition of beginning of new string
int charcount = 0; // keeps track of total chars on screen
#include <LiquidCrystal.h> // import the LiquidCrystal Library
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
void setup() {
Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
lcd.begin(16,2); // Initialize the LCD size 16x2. Change if using a larger LCD
lcd.setCursor(0,0); // Set cursor position to top left corner
pinMode(13, OUTPUT);
void loop() {
char incomingByte = 0; // for incoming serial data
if (Serial.available() > 0) { // Check for incoming Serial Data
digitalWrite(13, HIGH);
incomingByte = Serial.read();
if ((incomingByte == '~') && (startstring == 1)){ // Check for the closing '~' to end the printing of serial data
startstring = 0; // Set the printing to off
delay(5000); // Wait 5 seconds
lcd.clear(); // Wipe the screen
charcount = 0; // reset the character count to 0
lcd.setCursor(0,0); // reset the cursor to 0,0
if (startstring == 1){ // check if the string has begun if first '~' has been read
if (charcount <= 30){ // check if charcount is under or equal to 30
lcd.print(incomingByte); // Print the current byte in the serial
charcount = charcount++; // Increment the charcount by 1 yes I know it's awkward
if (charcount == 31){ // if the charcount is equal to 31 aka the screen is full
delay(500);
lcd.clear(); // clear the screen
lcd.setCursor(0,0); // set cursor to 0,0
lcd.print(incomingByte); // continue printing data
charcount = 1; // set charcount back to 1
if (incomingByte == '~'){ // Check if byte is marker ~ to start the printing
startstring = 1; // start printing
digitalWrite(13, LOW);
delay(10); // 10ms delay for stability
void setup() {
void loop() {
delay(500);
STEP 5: The Python Code
#import library to do http requests:
import urllib2
#import pyserial Library
import serial
#import time library for delays
import time
#import xml parser called minidom:
from xml.dom.minidom import parseString
#Initialize the Serial connection in COM3 or whatever port your arduino uses at 9600 baud rate
ser = serial.Serial("\\.\COM3", 9600)
i = 1
#delay for stability while connection is achieved
time.sleep(5)
while i == 1:
#download the rss file feel free to put your own rss url in here
file = urllib2.urlopen('http://news.sky.com/feeds/rss/world.xml')
#convert to string
data = file.read()
#close the file
file.close()
#parse the xml from the string
dom = parseString(data)
#retrieve the first xml tag (<tag>data</tag>) that the parser finds with name tagName change tags to get different data
xmlTag = dom.getElementsByTagName('title')[2].toxml()
# the [2] indicates the 3rd title tag it finds will be parsed, counting starts at 0
#strip off the tag (<tag>data</tag> ---> data)
xmlData=xmlTag.replace('<title>','').replace('</title>','')
#write the marker ~ to serial
ser.write('~')
time.sleep(5)
#split the string into individual words
nums = xmlData.split(' ')
#loop until all words in string have been printed
for num in nums:
#write 1 word
ser.write(num)
# write 1 space
ser.write(' ')
# THE DELAY IS NECESSARY. It prevents overflow of the arduino buffer.
time.sleep(2)
# write ~ to close the string and tell arduino information sending is finished
ser.write('~')
# wait 5 minutes before rechecking RSS and resending data to Arduino
time.sleep(300)
import urllib2
import serial
import time
i = 1
time.sleep(5)
while i == 1:
#convert to string
data = file.read()
#close the file
file.close()
ser.write('~')
time.sleep(5)
for num in nums:
#write 1 word
ser.write(num)
# write 1 space
ser.write(' ')
time.sleep(2)
ser.write('~')
time.sleep(300)
STEP 6: Getting It to Work.
Upload the Arduino Code to the Arduino itself. Put the Python code into a .py file. If all goes according to plan, if you run the .py file, you should see the text start appearing after about 10 seconds. Every time a word is outputted, the LED should flash as well.
If it doesn't work:
Check the port in the python file. Your Arduino may be labeled differently or be numbered differently.
Check that the RSS feed doesn't have a ~ in the data. That will throw things out of whack.
Try running the .py file from the command line as an administrator. Sometimes the script doesn't have proper permissions to access the COM ports.
If it doesn't work:
38 Comments
PaulKed 3 years ago
I know this is old now but in case anyone is stumbling upon it.
I am new to Arduino and never done python before but was having a play around and trying to learn a bit.
I found the code in this post to now work for the reasons mentioned above (encoding) and others - not sure if this ever worked.
Main issue was once the encoding was fixed the python RSS posting code never actually read past the first news feed.
Here is the code after i have made a few modifications for a 20X4 display but if using the 16X4 just update the Arduino code at top to 16x2 and in bode the 20/80 parts to 16/32 and remove the 40 and 60 section.
***Aurdino code
/* I2C LCD with Arduino example code. More info: https://www.makerguides.com
// Include the libraries:
// LiquidCrystal_I2C.h: https://github.com/johnrickman/LiquidCrystal_I2C
#include <Wire.h> // Library for I2C communication
#include <LiquidCrystal_I2C.h> // Library for LCD
// Wiring: SDA pin is connected to A4 and SCL pin to A5.
// Connect to LCD via I2C, default address 0x27 (A0-A2 not jumpered)
LiquidCrystal_I2C lcd = LiquidCrystal_I2C(0x27, 20, 4); // Change to
(0x27,16,2) for 16x2 LCD.
int iCount = 0;
void setup() {
to 9600 bps
lcd.init();
lcd.backlight();
corner
void loop() {
//lcd.autoscroll();
startstring = 0;
// Set the
printing to off
delay(3000);
// Wait 5 seconds
lcd.clear();
// Wipe the screen
charcount = 0;
lcd.setCursor(0,0);
// reset the
cursor to 0,0
if (++charcount < 81){
// check if
byte in the serial
if (charcount == 20) {
lcd.setCursor(0,1);
if (charcount == 40) {
lcd.setCursor(0,2);
if (charcount == 60) {
lcd.setCursor(0,3);
if (charcount == 80){
delay(1000);
lcd.clear();
// clear the screen
lcd.setCursor(0,0);
// set cursor to
0,0
charcount = 0;
startstring = 1;
// start
printing
delay(100);
//Python code
#import library
import urllib.request
import serial
import time
import feedparser
ser = serial.Serial("\\.\COM5", 9600)
i = 1
time.sleep(5)
while i == 1:
NewsFeed = feedparser.parse("http://feeds.skynews.com/feeds/rss/uk.xml")
NewsFeedEntries = len(NewsFeed.entries)
ser.write(str.encode('Number of News Posts :' + str(NewsFeedEntries)))
item = 1
for item in NewsFeed.entries:
#print ('Post Title :' + item.title)
xmlData = item.title
ser.write(str.encode('~'))
time.sleep(5)
for num in nums:
#write 1 word
ser.write(str.encode(num))
# write 1 space
ser.write(str.encode(' '))
time.sleep(1)
# wait 3 secs to allow reader to read line before page is refreshed
time.sleep(3)
#Wait 5 secs before the next news item
time.sleep(7)
RichardD79 8 years ago
I've hit a problem: "TypeError: unicode strings are not supported, please encode to bytes: '~'
-I'm very new to Arduino & Python but I believe the problem is the above code is Python 2, and I'm using Python 3. Can anyone please help? Thank you.
degardinarnaud 3 years ago
rikiris 7 years ago
found it. looks like the lcd cannot support unicode (only support ascii) so in python script change line : ser.write(num) to ser.write(num.encode('UTF-8'))
and the rss url is also not valid anymore, be carefull. it's just prototype so you have to revise all code based on your needs.
rikiris 7 years ago
did you found that problem? im having same errors
nodog445 4 years ago
russ_hensel 8 years ago
I love the combination of Python and the Arduino. So I have created a collection about it. I have added your instructable, you can see the collection at: >> https://www.instructables.com/id/Arduino-and-Pytho...
ChristianV3 8 years ago
How would I make this display weather forecast?
surya raju 9 years ago
Geeve George 9 years ago
I got this error when I ran the code in phyton , please help me out!
casey.lisak 9 years ago
Can this be done with a LED matrix?
misadeks 9 years ago
How can you use arduino code for a 20x4 LCD?
I tried changing the size in the code, but it does not work. When it comes to the second line it clears the lcd and the other part is displayed. Please help.
tkadere 10 years ago
line 39, in
ser.write(num)
File "C:\Python27\lib\site-packages\serial\serialwin32.py", line 283, in write
data = to_bytes(data)
File "C:\Python27\lib\site-packages\serial\serialutil.py", line 76, in to_bytes
b.append(item) # this one handles int and str for our emulation and ints for Python 3.x
TypeError: an integer or string of size 1 is required
techno guy 11 years ago
mshah9 11 years ago
callemang 11 years ago
