Introduction: Wobbly Blobbly
Wobbly Blobbly is a toy you can't knocked down.
I usually try to make things which serve a purpose in someway. Wobbly blobbly is just a bit of amusement with no purpose, other than to entertain. It came about as a extension from making a pen balancing holder a while ago as it reminded me of an inflatable toy I had as a child which when pushed over came back standing. Wobbly Blobbly is made using paper-mache or paper strips laminated over a balloon. Several fishing sinkers, glued in the bottom, cause it to always return upright.
Step 1: Partially Inflate a Ballon
Partially inflate a balloon to act as a mold
Step 2: Shape the Balloon
Wrap some sticky tape around the balloon to give it a longer shape. Have the non sticky side of the tape next to the balloon.
Step 3: Paper Mache
Tear strips of newspaper and stick on shaped balloon with paper glue. Apply multiple layers, overlapping the previous one.
Step 4: Àllow Paper Mache to Dry
After gluing multiple layers of paper, allow it to dry. This may take a couple of days.
Step 5: Dried Paper Mache
Check the paper mache is dry. It should be hard and ridged.
Step 6: Cut Into Two Halves
Cut into two halves and remove the balloon.
Step 7: Weight to Bottom
Add some weight to the bottom of one of the halves. I glued and tape in 3 lead fishing sinkers.
Step 8: Glue Back Together
Glue the 2 halves back together and apply some more paper mache strips.
Step 9: Paint
Once the paper mache has dried, apply paint.
