Introduction: Wood Box Making/Beautiful and Simple
I needed a box to store my toothbrush for my travels, so I decided to make this box
I filmed the entire process of making this box and put it on the YouTube channel
If you like, you can watch this video
If you like it, please like it.
If you have any questions, you can ask and I will answer them
(English is my second language, I tried to explain as completely and accurately as I can)
I used power tools in this project
1- Table saw
2- Wood glue
3- Paper glue
4-pencil
5- Ruler
6- Wood oil
Details of the box
Total dimensions
20 x 6 x 6 cm
Dimensions of the upper part
7 x 6 x 6 cm
Dimensions of the bottom part
13 x 6 x 6 cm
Wood used in the project
1- Ayous Wood
2- Paddock Wood
3-Wenge
Step 1:
In the first step, you will find a suitable piece
I made the necessary cut
I draw the pattern that is needed in the wood
I will give the necessary cuts
Step 2:
It seems that the triangle shape in this project gave an interesting shape to our box
It was interesting for me to use the combination of two colors together
If you like, you can draw other patterns on your wood
I liked this pattern
These cuts can be made completely smooth with the cutting machine on the table
Now I draw the same pattern for the second piece of wood.
I decided to have only two pattern pieces for the box
Our four pieces of wood, two pieces with pattern and two pieces without pattern
Step 3:
After the complete gluing stage of the box, the upper part of the box should be cut
To separate a few centimeters from the box with yourself
I cut 7cm to use as the top of the box
I will stick the last parts of the box
In the last step, I sanded it and used oil to make it last longer
