Introduction: Wood Cutting Saw
Hi, Friends
Welcome to creativity buzz.
You can make a circular miter saw using wood.
Step 1: Materials
1)775 DC Motor
2)DC Motor Clamp & Switch
3)10 Inch Slider
4)Ginder machine adapter
5)$ Inch Saw blade
6)Wood
Step 2: Cutting Wood
Cutting wood in this shape of dimension.
1) 35 X 11 CM
2) 2 Nos. 25 X 4 CM
3) 2 Nos. 30 X 5 CM
4) 10 X 4 CM
5) 13 X 10 CM
6) 20 X 6 CM
7) 13 X 10 CM
Step 3: Fitting of Slider
Make holes in the wood plate and fit drawer slider in this wood.
1st thing Line the saw up on the plywood. Then mark a line along the base of the saw, on the end that's the furthest from the blade. Measure the line from the edge of the plywood to the mark that was just made. Carry that same measurement the distance of the plywood.
Take a straight object to make a straight line. In my case I used a Aluminum tubing. Now trace the line from end (Im still referring to the very 1st line from the edge of the saw base) Next move your straight object (aluminum tubing). Now measure from the router bit to the end of the router base. That's the distance you want to set your straight object from the line that I drew out first.
Step 4: Join the Handle
Join Handle as the picture.
Step 5: Connect DC Motor
Connect DC Motor To wood plate using aluminum brackets.
Step 6: Join Handle Bar and Base Plate
Joint the handle and base using the hinge.
Step 7: Joint the All Material
Joint all materials to the dc motor.
Step 8: Wiring Diagram
Make wiring using pictures and supply 12-volt dc voltage.
Step 9: Experiment
Cut wood using this machine.
