Introduction: Wood Spool - Bobbin - REEL
wooden spool - Bobbin - reel
Step 1: Step 1; Scrap Wood Metal Can
you will need some scrap plywood or solid wood
Step 2: Step: 2 the Tools You Will Need
you will need
the tools show 2" and 3 ½ " and a glue gun as shown
Step 3: Step: 3 Start Drilling
use the 2" just to go
½ way throw the material you are using solid wood or play wood
Step 4: Step : 4 Cut Out the Shaps
then use the larger cutter to cut it out as shown in solid wood and play wood
Step 5: Step: 5 Start Gluing
start gluing
apply hot glue to the
inner wood cavity then press firmly the empty can in cavity
(note) you can also use 2 part epoxy that will be much stronger too on this project
Step 6: StEP : 6 SAND AND FINISH
SAND THE EDGES
sand edge just so there is no splinters
- I routed the solid wood one but sanding will do the job
just as good 100 grit or 120 grit is fine
OPTIONAL IF YOU HAVE A ROUTER
I USED A ROUTER ON THE WOODEN SPOOL SHOWN IT DID A REAL PRO -JOB
Step 7: STEP ; Apply Clear Coat or Paint
a good clear coat will look nice or wood stain or any color you wish to use
ENJOY YOU SPOOLS - BOBBINS -- REELS
