Wood-fired Pizza on a Gas Grill
Intro: Wood-fired Pizza on a Gas Grill
Pizza is dead easy to make and are sure fire hit with any crowd!
This method will have you cooking pizza on your basic Gas Grill that is as good as any traditional wood fired oven.
STEP 1: First Make the Pizza
Use a packet of “Crusty” bread dough mix for bread machines, these packets have everything you need.
Most bread machines have a dough cycle or use a mixer with a dough hook - just follow the instructions on the bread mix packet for "Hand Kneaded" or Bread Rolls, this dough has a little less water and will produce a stiffer dough.
A 3’ish cup mix will give 4 medium pizzas (thin crust) or 2-3 thick spongy ones
Once the dough has formed, coat the inside of a large container with oil, place the dough in it and set it aside to prove.
STEP 2: Roll Out the Dough and Prepare the Base
Once the dough has proved, divide it into portions.
Roll a portion out into a circle, the same size as your pizza tray
Flour the pizza tray and transfer the dough to it
STEP 3: Dress the Pizza
I've never got time to make my own sauce because I'm an impulsive bastard so when I want pizza, I want it now!
Choose a good Passata, and add some crushed garlic to it. If you can remember, do this at the same time as you mix the dough, the little bit of time the garlic has to infuse the passata will greatly improve the flavour.
Spread the Passata evenly over the pizza base.
STEP 4: Add the Toppings
Now the fun part!
The choice of toppings is up to you, just remember a couple of rules:
- Cut everything as thin as you can, this will help the toppings cook quickly
- Avoid Moisture, Wet toppings or toppings that release moisture as they cook will make your pizza soggy, squeeze the moisture out of things like olives, pineapple etc
- Don't put too much on! The thicker the layers of toppings the longer it will take to cook and the soggier your pizza will be.
Start with a layer of cheese, this helps stick the ingredients to the base, I like to finish with a little cheese as well, this will stop bits from falling off.
STEP 5: Set Up Your Gas Grill
If you have a four burner gas BBQ with a hood, remove the solid plate and move the grill bar plate to the centre of the barbecue, get the barbecue nice and hot by using all burners on high then turn the centre ones back to low before cooking.
Eliminating the solid plate helps the air flow around your pizza and will give a nice crisp crust.
Place three empty cans on the grill, the pizza tray will sit on top of them, this places the pizza up into the hottest part of the BBQ Grill where all the hot air is circulating and it creates some distance between the base and the direct heat from the flames. Setting it up like this will ensure your toppings will be cooked when the base is.
Devise a method to ensure nobody throws your cans out, I have found that small children and visiting mother-in-laws universally understand simple symbols which spouses apparently do not
STEP 6: The Wood-fired Cheat
To get that "wood-fired" taste on your pizza, you don't need a lot of smoke, just a thin wisp.
One of those stainless steel trays full of wood-chips will do the trick set down on the burners, but more often than not, I just sit a small wooden block directly on the back of an exposed burner
STEP 7: Cook That Pizza!
Light the burners and get the Gas Grill as hot as you can.
Place the Pizza tray on top of the cans, close the lid and set a timer for 5 minutes.
After 5 minutes check your pizza, look at the toppings and lift a corner of the base to see if it is cooked. You might need to keep cooking for a minute longer.
STEP 8: Serve Your Pizza
Remove the pizza from the Gas Grill.
Slide onto a heatproof surface and cut into portions.
While you are stuffing your face, roll out and prepare another Pizza!
STEP 9: For a Bit of Fun
Need a good laugh?
Here is a video I did on the technique many years ago!
16 Comments
pmillho 4 years ago
Also I don't recall seeing passata in the grocery stores here in the US, could we just substitute a good quality marinara or pizza sauce?
ClaudioP34 1 year ago
UrbanGriller 4 years ago
Yes it can be cooked on a charcoal grill with a good hot fire. The mixer just makes life easy, you can hand-make the dough if you need to, I've done it many times while camping
stumitch 4 years ago
ciscomancer 4 years ago
KagedCreations 4 years ago
StefanoB76 4 years ago
Usate almeno i vostri prodotti e venite in Italia a mangiare roba buona.
E poi denigriamo i Cinesi perché copiano le cose !
"Why do you use the past Val Verde, which is Australian, and pretends to be Italian?
Use at least your products and come to Italy to eat good stuff.
And then we denigrate the Chinese because they copy things!"
I use the Val Verde Passata because I'm in Australia and that is what our supermarkets have, back on the farm we would make our own once a year from fresh tomatoes. I'd love to go to Italy and enjoy its food one day, I just need to win the lotto first, so I can buy a ticket.
Dal 2016, in Australia, ci sono dazi per le importazioni dei prodotti alimentari italiani.
Per fare la passata di pomodoro si usa la varietà " butaline ", la più comune delle varietà di pomodoro, penso che le abbiate anche voi e che siano buone uguale.
Sono arrabbiato solo perché una qualunque azienda, in qualunque parte del mondo, applica una bandierina verde, bianca e rossa ed il prodotto assume subito un altro valore.
Nella mia zona è cresciuta una forte produzione di kiwi, sui mercati si vendono come prodotti in Piemonte e non si mette una bandierina come provenienti da New Zeland.
Comunque smettiamola qua, spero che col tuo sistema tu riesca a mangiare una buona pizza, a prescindere da cosa ci metti sopra.
Scusa se scrivo in italiano, ma così riesco a dare un senso al mio discorso, poi ci penserà Google translate a farlo diventare ridicolo.
Buona giornata dall' altra parte del mondo.
fthies 4 years ago
drlexluthor 4 years ago
MaraCreates 4 years ago
jessyratfink 4 years ago
