Introduction: Wooden American Flag
I was fascinated by these flags and had to figure out how to do it! I found a couple tips here and there so now I'm going to try putting it all together the best I can for everyone here!
Tools used:
Tape measure
Speed square
framers square
miter saw
table saw
orbital sander
couple wood clamps
Dremel
wood chisel
brad nailer
propane torch
Materials:
1"x4"@8' (is what i buy)
Minwax blue stain
Minwax red stain
Rustoleum marine varnish
wood glue
Step 1: Cutting It Up!
I bought a star stencil from amazon for a couple bucks but has been well worth the investment. The size of the template determined the size of the flag. You can go on to google and get flag dimensions a couple quick measurements and some simple math and you got your sizes.
For mine I am cutting my boards to 24.75" in length. After I cut enough pieces so I will be able to have 17 strips after running through the table saw I sanded the top surface.
I then set my table saw to rip these at just over 1" so I would have about a 13.25" total with all 13 strips together. the other 4 strips will be used to hold it all together!
Step 2: Burn It Up!
After you have the 13 strips you want (I would make sure to use the straightest pieces you have)
It's time for the fun! bust out the propane torch and hit the boards and make some grain pop! this is all at what you like!
*be careful with the torch*
As Frankenstein says "Fire Bad"
layout your strips how you want them. I use framing square to make sure I got this nice and square. then top left corner line up your template and lets put a line down the edge on the boards!(so we got visual of where the blue needs to stop)
Now for my own sanity I flip the pieces over and label them 1-13 so I keep the burn pattern how I like it.
The pieces that will be getting the blue stain I take razor blade and press into the wood on that line that way I have nice crisp clean lines.
Step 3: Slap Some Stain on It!
pretty simple deal here!
Step 4: Tightening It Up
Ok heres where the fun gets closer to being out the door! lol
put strips face down Use square and wood clamps to get everything lined up and square. (I check my numbers and make sure i have 1-13 again)
Trim the 4 extra strips down to 13"
slap a little wood glue on the 4 extra strips and use the brad nailer and make sure the flag stays together!!
Step 5: Looking Good But Here Comes the Work.....
After the glue is dry remove the clamps and flip it over! now bring back the stencil and time to outline the stars onto the blue! I use a silver sharpie.
After all 50 are on there I use a Dremel with the 106 bit to go over the outline and then a quick rough over to clear out the center waste. I then go back through with my wood chisel and clean up the lines and the recessed wood. This is all the time of this project but the results are well worth it!!!
Step 6: Finishing!!!
after all the removal of the wood chips and dust. time to pull out the varnish! I use a marine grade and put several coats on the flag so the weather will not destroy it! After it dries throw some hanging hardware on the back take it outside and put it up and show it off with pride!
Thanks for checking this out! If you liked it please give me a vote in the contest! I will be publishing more projects on here soon, follow me and I will try keep posting a new project every couple weeks! Thanks again!!!
