Introduction: Wooden Animal
How to make a toy animal by Tyler
You will need: Wood
Wheels
Axels
Miter Saw
Drill Press
Band Saw
Paint (optional)
Step 1: Choose an Animal
First, choose an animal, I chose the Homosapien. Then print it out onto a piece of paper. You will then make the animal more animated, and draw where the wheels should be.
Step 2: Make a Template
You will then trace the cut-out onto Matt board and cut that out using a utility knife.
Step 3: Cutting It Into Wood
Then you will trace the template onto a piece of wood, then cut the wood out using a band saw.
Step 4: Drill the Holes
Then you will drill the holes out with a drill press
Step 5: Router and Sand
Then router the edges, and sand the entire thing.
Step 6: Paint It (Optional)
After that, you can paint it, and I will provide the steps. You first will draw out and color a painting plan. Then you paint it.
Step 7: The Wheels
Then you will glue the axels in, and attach the wheels, and turn the wheels around to loosen them up.
Step 8: Done!
Now you can play with your toy, or give it to someone, or even just put it somewhere for decoration!
