Introduction: Wooden Carrying Car
This device will help to deliver an object from one place to another.
4 screws 4 washers A sander or piece of sand paper A drill A hold saw A chop saw A 20 inch piece of wood. ¾ of an inch thick Any number sticker you want A rubber band
Step 1: 1.
Measure out and draw four 2 inch circles on a piece of wood
Step 2: 2
Go to the hole saw and use this to cut out the four circles.
Step 3: 3
Sand these circles down so that they are smooth all around since these are the tires and will need to roll.
Step 4: 4
Now we will move on to cutting the body to size. You want to measure out 9 inches by 3.5 inches in the wood.
Step 5: 5
Next go over to the chop saw and cut this part out
Step 6: 6
Sand down the sides top and bottom because you do not want anyone getting a splinter when they reach for the remote.
Step 7: 7
You have the option to curve the front of the car if you please. Make a diagonal cut on each side of the front of the car. Sand the front in a rounded formation to round the front.
Step 8: 8
Now its time to put the car together. Measure out four equal distant dots on the sides of the car. 2 on each side to mark where the tires will go
Step 9: 9
Then take your drill and make little in cuts on the dots so you will have a space to place your screw
Step 10: 10
Put the screw through the tire and then put the washer on the opposite side of the screw.
Step 11: 11
Screw each tire in leaving just a little bit of space between each tire and the body of the car so that they spin smoothly.
Step 12: 12
Place the rubber band around the body in between the the tires so that it will be able to hold down any object place on it.
Step 13: 13
Now your car is ready but if you have that sticker stick it on top and you have a racer
